Brake System Overhaul
Old May 10, 2011 | 08:06 PM
Dman98's Avatar
Dman98
Default Brake System Overhaul
I've been experiencing a hard brake peddle for some time now and decided do an overhaul. During panic stops, the she slows down and takes a while to stop. Everything appears to be working properly and my research points to the power booster. So I plan on changing the booster, the master cylinder, the rear wheel cylinders and the brake line that goes from the front to the back due to rust. I'll also be upgrading to a better brake fluid as well and all the parts will be purchased from Rockauto except the fluid. If anyone has advice or tips it'll be appreciated.
Old May 10, 2011 | 09:46 PM
WhiteWidow00's Avatar
WhiteWidow00
I would say start with the brake booster first and foremost because usually a hard brake pedal leads to the booster, and if the pedal gets a spongy feel to it, it's usually a master cylinder. Also, what do you mean you'll be upgrading to a better brake fluid? Do you mean like a synthetic DOT3 because I wouldn't advise straying too far away from DOT3 brake fluid (for instance DOT5 "Long Life Silicone Brake Fluid").
Old May 11, 2011 | 02:10 PM
Dman98's Avatar
Dman98
Lightbulb
I was thinking of using this; http://www.amazon.com/Super-Blue-Bra.../dp/B000JL0YMO
Old May 11, 2011 | 10:57 PM
IndyDurango's Avatar
IndyDurango
Why? If you are going in with all brand new stuff/hardware and need/want a new fluid... I strongly suggest Motul 5.1
IndyDurango
Old May 12, 2011 | 11:26 PM
hydrashocker's Avatar
hydrashocker
Never heard of it Indy, but it sure looks great! http://www.motul.fr/us/en-US/products/77
I only wish I could read the MSDS sheets?
Old May 13, 2011 | 12:32 AM
IndyDurango
LOL HS. Try the United States site instead of the French site.
Here: http://www.motul.com/us/en-US/products/77
When I replaced all my setup, that is the fluid I went with. Race proven, superior to DOT 3 & 4.
Just remember, you want 5.1.... not 5. They are not the same. The ".1" is backwards compatible with 3 & 4. Straight 5 is NOT.
IndyD
Old May 13, 2011 | 09:45 PM
Dman98's Avatar
Dman98
The booster came today, the other items won't arrive until the end of next week. They were shipped from a different warehouse, here's some pics for your enjoyment;
Old May 15, 2011 | 03:13 PM
Dman98's Avatar
Dman98
I need to change the rear brake line and I'm thinking about bending my own. Does anyone know the diameter of the brake line, I don"t have a measuring tool.
Old May 15, 2011 | 04:30 PM
hydrashocker
Not sure on the lines as I can measure them but don't have the Durango....LOL
If you look at the link it was the same......LOL
What I was talking about is the MSDS sheet was in French, however I did finally find it in English. http://www.quickfds.com/cmt_bin/wfds...CPdf=&Session= In it states:
100% synthetic fluid, polyglycol bases
Do not mix with silicone (DOT 5 silicone base) or mineral base fluids (LHM).
Maximum Storage: 24 Months
So this means our DOT3 fluids are covered like you said. I did find a fluke in their sheet though, Polyglycol Base oils are only good to -30F and up whereas they state -40F and up so I wonder how they can claim that? I have also seen claims of others like SynLube stating -65F. Also just like regular brake fluids, Polyglycol is incompatible with Petroleum's just like regular DOT3.
Very interesting fluid.
I have heard that some German vehicles ABS brake components don't like it though and they use the Fully Synthetic Valvoline DOT3 or DOT4.
http://www.valvoline.com/products/co...brake-fluid/28
Old May 15, 2011 | 05:55 PM
IndyDurango
No. Link wasn't the same. You had the .fr and I had the .com. You were on the French site thus the French info.
"you heard" what exactly? 3 days ago you had never even heard of Motul at all. In the end, 5.1 is the replacement standard for 3 & 4 thus over time all manufactures are headed that way.
IndyDurango
