Having trouble refueling my 2001 Durango
Old Jun 6, 2011 | 07:17 PM
  #21
hydrashocker's Avatar
hydrashocker
OK guys,
I would get under there and remove the filler. Maybe the vent is plugged or there is corrosion in the larger filler tube or smaller vent tube.
No there isn't any check valve or anything like that, it's a straight shot down into the tank. However if everything is good then I would think the problem lye's with the angle of the larger filler tube and the tank. If the rubber hose into the tank is flat then as the fuel aerates during fill the pressure comes up the filler and throws the vacuum breaker on the fuel spigot therefore turning it off.
For example, when I'm filling my tank I have to pull the spigot half way out to relieve the back pressure and keep the pump from shutting off.
Old Jun 7, 2011 | 11:14 AM
  #22
rob[GL]'s Avatar
rob[GL]
Yup... As I said before, I rarely have trouble fueling my vehicle, it's only at some gas stations... And usually pulling the nozzle half-way out solves the issue.
If you guys are having trouble fueling at every single gas station, all the time, there's probably something clogged.
Old Dec 7, 2012 | 02:08 PM
  #23
murph2221's Avatar
murph2221
Default Any resolution?
Originally Posted by BDWJR78
Thanks to everyone saying to hold the nozzle a different way or 1/2 way out, but as I stated in an earlier post it doesn't matter which way I hold the nozzle, how far it is in the fill tube or not in the fill tube it still shuts off. Nothing changes the way it fills but it takes like 10 mins. or longer to get a half of a tank of fuel, "Does any one know if this vehicle has a refuel check valve" thats was the original question. And if so where it is located in the tank, like the vehicles I work on for a living (Toyota) or is this system different I have looked on Mitchell on demand at repair manuals for this and can not find it anywhere.
My 2001 Durango 4x4 is just as bad...BDW, did you or anyone else ever resolve this problem?
