A/C blows just not thru vents
Old Jun 1, 2011 | 01:59 PM
browning725's Avatar
browning725
Default A/C blows just not thru vents
I have a 2000 Durango 4.7. My a/c is still blowing it just seems as though it's not making it to the vents (dumping in the dash). Sound common or familiar to anyone? Would greatly appreciate any help.
Old Jun 1, 2011 | 02:21 PM
WhiteWidow00's Avatar
WhiteWidow00
Does the heat or air other than A/C come through the vents? If so, I have a feeling you have a blend door stuck under the dash.
Old Jun 1, 2011 | 08:02 PM
samnbensdad's Avatar
samnbensdad
I had that problem with my 02. It was the mode cam actuator that controls the blend door. One of the screws worked itself loose. It is found in the lower dash, near power outlet.
Old Jun 1, 2011 | 08:35 PM
srch4me's Avatar
srch4me
could also be a vacuum line gone bad somewhere as well... that was my problem...
Old Jun 1, 2011 | 08:49 PM
devinpitcher's Avatar
devinpitcher
+1 on the vacuum. My hose from the firewall to the main vacuum line was missing, so I had to run a new hose into the dash.
Old Jun 1, 2011 | 09:02 PM
srch4me's Avatar
srch4me
yeah... when i replaced my collapsed vacuum line all of a sudden like magic my cruise started working, air vents started working... amazing what a small $1 part can affect.
Old Jun 1, 2011 | 10:51 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
ok you guys are talking about 2 different hvac system setups, 98-00 had vacuum actuated doors, mid year 00 i believe, they switched to electric actuators, so either his electric actuators are gone bad, or he has a broken vacuum line
just needed to clarify.
Old Jun 2, 2011 | 03:46 AM
srch4me's Avatar
srch4me
Thanks sharp... i definately did not know that... now i do amazing all the information you pick up just bein on here lol
Old Jun 2, 2011 | 05:34 PM
browning725
Default Thanks
Thanks for steering me in the right direction guys. My wife is on a road trip in it and I'll have to wait til she gets back to look into it. Thankfully, for her sake, she said it just started working again out of nowhere. (told her not to touch a damn thing til I get it fixed, lol)
Old Jun 2, 2011 | 08:44 PM
devinpitcher
You probably have the electronic controlled one then, since I doubt a damaged vacuum line will just fix itself. Possible, but unlikely.
Let us know if you ever find anything out later on.
