AC Compressor started tapping
Whenever the AC is on, the compressor makes a constant tapping noise. This afternoon on my way home from work I noticed the AC will only blow cold if Im accelerating and blows almost warm when stopped at a light. What is everyones thoughts? Recharge? Clutch in the compressor?
Thanks!
Thanks!
just shine a flashlight in there w/ the engine running and the a/c on, it should be spinning, if not do this
1) swap the e-fan relay with a matching number, if that doesnt work
2) check the fuse (should be labeled in the lid of the PDC)
3) jumpt 12v to the fan leads directly (you can use the battery, but i would use a charger if you have one just in case. . .) if this doesnt work you need a new e-fan
Trending Topics
