My Newest Project
Ok, so I have my 2000 Durango Sport, and it came with the (boring)cloth seats. I wanted to go with leather. So, after a year of searching, I found a whole set...but the front seats were ripped. I couldn't pass up the back seats though, so I picked um up for $50(for both rows). I then started searching for front seats, and 2 hours later I had found some....they are Leather/Cloth R/T edition seats. They match up perfect with the rear seats(excluding the R/T trim, which I do not mind) Now of course, they are power and heated, and I have the switches and also the connectors for underneath the seat, but my car does not have power seats. No problem really, thats an easy fix. Now, all I need is the wiring harness that goes from the center console to both seats, including the wires up to the switches(the switches I got have the wires, but do to the workers not being "bright", they cut them off instead of unplugging). If any of you know where I can pick one up, let me know. Pics will come sometime after I finish.
That's actually where I found everything. I need one little thing though, does anyone know what fuse number 21 is on a 2000 Dodge Durango? Im thinking it can be used for a power source for my 'Rango's power seats, since there is no fuse in slot 21 and it has power.
I wanted to update this(Even though it has been such a long time). I did complete this project, and it turned out teriffic. I used the 25 amp fuse to power the seats(my wiring wasn't exactly pretty, and I just have the wire along the fuse in the box). All power works, and I had some issues with the center console. Since mine had the seat/console, I wanted a console that would A. Fit and B. Match. I found a light gray console, and painted it black(as my interior is dark gray). I also recieved the heating duct with the console. Since mine(in the vehicle stock) wasn't set up the same, I had to modify the existing duct. I cut it, and fit in the insert that allows the air to flor to the knee level vents in the console. To be quite honest, this was a novice project all and all, and it took me longer to find the seats then to install them. HOWEVER. I could not find the cluster I needed for the heaters, so, i just didn't wire them for now. I may not even do it.
Trending Topics
Not sure it would fit too easily, but if you ever come across the right colored console in a 2001-3 it would have the cut outs for for the switches. I'm not sure where the heat switches would go on the older style console, and you'd have to cut the holes out since the seats weren't heated until 2001 I believe.
Umm... 98-00 from the factory never got heated seats, let alone heated seat switches. Not really sure what you're talking about.
However, where you mentioned is the best place to put the switches if you put 01-03 heated seats in and have it look factory. It's a VERY tight fit, and you need to trim the carpeting away to allow enough room for the switch plugs and wiring.
First install with my old tan interior...
![Name: IMG_3523.jpg
Size: 54.3 KB](https://dodgeforum.com/forum/attachments/1st-gen-durango/60413d1501328677-my-newest-project-img_3523.jpg)
When I switched to the graphite R/T interior I cut the switches closer together, which made it a little easier to see the right switch with a cup in the cupholder.
![Name: a4b8de3b.jpg
Size: 53.3 KB](https://dodgeforum.com/forum/attachments/1st-gen-durango/60414d1501328677-my-newest-project-a4b8de3b.jpg)
Section of carpet you have to remove:
![Name: f5fd0478.jpg
Size: 55.0 KB](https://dodgeforum.com/forum/attachments/1st-gen-durango/60415d1501328677-my-newest-project-f5fd0478.jpg)
