Any quick fix for a blocked A C drain ?.
Old Jun 20, 2011 | 07:03 PM
neilb's Avatar
neilb
Default Any quick fix for a blocked A C drain ?.
My front A C drain is blocked, I know this cos I usualy have 2 puddles of water under the truck, one at the front and one at the rear, now I only have a puddle at the rear, and a puddle in the passenger side foot well, not good. So is there an easy fix for this, I did look in the "sticky" about A/C, but wondered if any one could give me some good tips on how to rectify this problem. Thanks muchly, Neil.
Old Jun 20, 2011 | 07:05 PM
topdogcustoms's Avatar
topdogcustoms
run a piece of wire through the hose
Old Jun 20, 2011 | 07:14 PM
neilb's Avatar
neilb
Duh !, lol, well sometimes I am a little slow, hey will a shot of compressed air be okay, I just dont want to damage anything, and thank you.
Old Jun 20, 2011 | 07:39 PM
topdogcustoms
i wouldn't use air you will be fine with a piece of wire
Old Jun 20, 2011 | 09:06 PM
neilb's Avatar
neilb
Thanks.
Old Jun 20, 2011 | 09:40 PM
Wineluvr2's Avatar
Wineluvr2
Mine is plugged as well. Can you tell me where the drain is located specifically? Thanks!
Old Jun 20, 2011 | 09:47 PM
topdogcustoms
passenger side firewall
Old Jun 21, 2011 | 09:17 PM
Wineluvr2's Avatar
Wineluvr2
I have looked all over that side of the firewall. Is it behind what looks like a foil covered heat shield behind that side of the motor? (4.7L) Thanks!
Old Jun 21, 2011 | 09:36 PM
atthewmartin114's Avatar
atthewmartin114
role down the window and pull it all out you save gas gain a few hp. the only thing you have to get over is dealing with is the wife yelling about it being too hot.
Old Jun 21, 2011 | 09:53 PM
samnbensdad's Avatar
samnbensdad
You don't really gain many MPGs by rolling down the windows due to the loss of aerodynamics.
