2003 SLT strange transmission indicator light problem
Old Jul 5, 2011 | 09:35 AM
Bobman's Avatar
Bobman
Default 2003 SLT strange transmission indicator light problem
Ok, here's a new one.... I started my truck on Saturday morning and observed that all of the gear indicators on the dash ( P R N D 2 1) ALL had the box around them. I moved the shifter and they all stayed lit. I put it in park, then moved it back one, they all stayed lit but I was able to back out. Moved it two more to put it in drive, started moving and the "block" that highlights them stayed on D and turned off for the rest of them.
It's happened twice more since then, only when I startup, and it goes away after 20-30 seconds. The last time I just sat there in park without moving and watched it go away.
Ideas? It's a 2003 SLT 4WD w/ a 4.7
Thanks,
Bob
Old Jul 5, 2011 | 04:27 PM
hydrashocker's Avatar
hydrashocker
There is a TSB on that issue but I can't find it. 1800503C
Look around, I know master tech has it and he has posted it here before.
Old Jul 6, 2011 | 09:36 AM
Bobman's Avatar
Bobman
Hydra,
Thanks, I never thought to look at TSB's. I found that the TSB was updated to 18-013-04 and requires a firmware flash. Guess I'll have to contact a dealer (Grrrrr....) to see if it can be accomplished. Funny that the problem just showed up now, since the upgrade was discovered in 2004?
Thanks again,
Bob
