Check gauges light - Durango died
The Check Gauges light came on then it got worse. The light came on but it was running so I headed home. The only thing I noticed was that the battery gauge wasn't showing anything. After a bit, the "abs" and brake light came on, then the air bag light. Soon the radio went off. I stopped and checked and the battery cables they were pretty corroded. Turned off engine (stupid) and it wouldn't restart. Pulled off neg and cleaned, got it to restart. Continued on only to have the tach, speedo and all gauges turn off. They would come on and go off a couple of times then she died at an intersection stop sign. Got her to start with a jump but only made it another 10 miles before she died, good news right in front of O'Reilly's. Battery was shot so I replaced it and rushed home. The Check Gauges light was still on.
Could it be the alternator. Could it have just been the battery but why is the light still on?
Any suggestions?
THANKS
Any suggestions?
THANKS
2001 4x4 SLT AWD
Any suggestions? THANKS
Ok I checked for new codes and got P1682 Charging Sys Voltage Too Low. I started her up and didn't have the check gauges light anymore. How do you check the relays in the main fuse box by the battery (4 prongs)? I did notice that the one next to where the alt attaches to the box and on to the battery was sitting up, I pushed it down about 1/8 - 1/4 of an inch.
Thanks
Thanks
Thanks
Thanks
Sounds like the alternator went out and that was caused by the bad battery.
I would just replace it sense you replace the battery anyway and you don't want your bad alternator to take out your new battery. They like to go out together.
But as Old School said:
Get a multi-meter and place it on "20 volts DC". Measure the voltage between the battery cables (should be around 12.7 volts), then start the truck and measure it again and you should see it around 14.4 volts, if not replace the alternator.
The following users liked this post:
Dianna1972 (11-26-2022)
Trending Topics
I had the alt tested when the check gauges light came back on. The gauge on the dash was fine than dropped to zero and thats when the light came on. When I had it tested in car it failed I checked for codes and no new code the 1682 went away after replacing the battery. When I removed it and had it tested again it passed twice??? It seems fine when I start it then the gauge drops and the light comes on.
