My 2003 durango codes
Old Aug 3, 2011 | 04:22 PM
tressa5's Avatar
tressa5
Default My 2003 durango codes
My 2003 durango 4.7 2wd codes are P0456 evap leak small(0.02)and P463 fuel level sending unit volts to Hi. I put new gas cap on, reset codes and after several starts the codes came back. Now what?
Old Aug 3, 2011 | 04:59 PM
samnbensdad's Avatar
samnbensdad
The leak is most likely caused by brittle/cracked hose leading to the charcoal canister. Crawl under the drivers side door, look for black box in front of the gas tank. Once you find it, inspect the hoses coming from the box. I bet one is cracked.
Old Aug 3, 2011 | 05:39 PM
hydrashocker's Avatar
hydrashocker
P0456 Evap Leak Monitor Small (0.020) Leak Detected
P0463 Fuel Level Sending Unit Volts Too Hi
P0456 --- Could be a bad gas cap or leak in the lines at the carbon canister.
P0463----I've never seen this one, however it could mean that the resistor on the fuel pump is going bad and you would need to replace the fuel pump. It is an all in one unit about $200 bucks.
You do seem to have a lot of problems with codes, was this truck taken care of and all of a sudden these issues occurred or is this all of a sudden?
https://dodgeforum.com/forum/1st-gen...e-durango.html
https://dodgeforum.com/forum/1st-gen...hat-to-do.html
