tansmission fluid capacity
Old Aug 21, 2011 | 08:25 PM
MAGIC84's Avatar
MAGIC84
Chiltons says 5.0 qts capacity for fluid. Total replacement, as in torque converter or reservicing after overhaul/rebuild 14 qts.
I would get 6 or seven to be on the safe side, remember dont open the sixth and seventh bottle until you are sure you need it. You might be able ot return it as long as the bottle is not opened. The safety seal broken by most retailers would be onsidered opened.
Old Aug 26, 2011 | 01:33 PM
MattKendall's Avatar
MattKendall
think i am going to go with the valvoline atf4.. full drain and refill though.. just hit 90k yesterday and i have no records from the previous owner that he ever changed it.. royal purple would be nice, but not sure enough about the acceptance from mopar to try it just yet..
Old Aug 26, 2011 | 08:56 PM
MAGIC84's Avatar
MAGIC84
Good choice, I have put Valvoline ATF+4 in two services without any problems, if you hit 90 without any previous documentation then it would be good to have a known starting point for new fluid. Remember there are two filters, the blade type and the spin on oil filter type, last time I drove around to three different places and still wound up going to the dealer for the filters just food for thought. If you hit dealer don't forget the RTV Tell them it is the RTV sealant for the 545RFE transmission pan.
Old Aug 27, 2011 | 02:43 PM
hydrashocker's Avatar
hydrashocker
Royal Purple is not an approved Chrysler product!!!!!
Don't do any type of transmission flush!
Listen, don't even bother with the purge unless your fluid is burned. Just drop the pan replace both filters and fill it back up, make sure you do not over fill!!!! Use ATF+4 fluid only. I will tell you to use Valvoline Fully Synthetic ATF+4 and you will need 5-7 quarts to do so in your specific transmission. You can reuse your gasket by simply putting a little grease on the gasket (just enough to wet it) and re-install. This will get most of the old fluid out anyway, just not all of it.
Yes, I am toying with Mobil One Fully Synthetic ATF but that is completely different and a test if anything.
Old Aug 27, 2011 | 10:55 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
just a reference point, check your owners manual, the trucks which came with ATF+4 as the factory fill have 100k mile transmission fluid changes (i think ATF+4 is 2000 and newer)
Old Aug 28, 2011 | 12:19 AM
master tech's Avatar
master tech
Site Moderator & Tech
If you are replacing the filters on a 45RFE/545RFE it will take 8 to 10 qts to fill.Here are some specs, this way you don't need to look in the chilton book.
SPECIFICATIONS - FLUID CAPACITIES
DESCRIPTION SPECIFICATION
FUEL TANK 25 U.S. Gallons (95 Liters)****
ENGINE OIL
4.7L - with Filter 5.7L (6.0 qts.)
5.9L - with Filter 4.7L (5.0 qts.)
COOLING SYSTEM
4.7L 12.6L (13.3 qts.)***
4.7L with rear heat 13.4L (14.1 qts.)***
5.9L 15.5L (16.3 qts.)***
5.9L with rear heat 16.3L (17.2 qts.)***
AUTOMATIC TRANSMISSION
Service Fill - 46RE 3.8L (4.0 qts)
O-haul Fill - 46RE 9.1-9.5L (19-20 pts)
Service Fill - 45RFE 2WD - 5.2 L (11 pts.)
4WD - 6.2 L (13 pts.)
O-haul Fill - 45RFE 13.33L (28.0 pts.)
Dry fill capacity Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these figures may vary.
TRANSFER CASE
NV133 1.18L (2.5 pts.)
NV233 1.18L (2.5 pts.)
NV244 1.35L (2.85 pts.)
FRONT AXLE
C205F 1.66L (3.5 pts.)
REAR AXLE
8 1/4 in. 2.1L (4.4 pts.)**
9 1/4 in. 2.3L (4.9 pts.)**
**When equipped with Trac-lok, include 118 ml (4 oz.) of Limited Slip Additive.
*** Includes 0.9L (1.0 qts.) for coolant reservoir.
****Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing tolerance and refill procedure.
Power Steering
Power steering fluid capacities are dependent on engine/chassis options as well as steering gear/cooler options. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these capacities may vary.
