Front end Whine
Old Sep 4, 2011 | 11:07 PM
Tigrpawz's Avatar
Tigrpawz
Default Front end Whine
Greetings,
I have a 2000 Durango 4wheel drive, 2 wheel anti-lock breaks. For a week or so, there has been a whine in the front end when we get to about 20 mph and grows louder as speeds increase. If you turned the wheels to the right, the whining stopped.
After some research, it was figured that the front hub assembly was bad. We bought another assembly and replaced it. The whine was still present, if we turned the wheels to the right, the whine still would stop.
The information we researched was if you turn the wheels to the right, the weight would be shifted from the front right to the left.
If any of you could, we would love some input on this.
Thank you in advance.
Old Sep 5, 2011 | 12:52 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
When replace hub bearings, I always recommend to replace both sides. For this reason. Do you still have the old bearing you removed? I would put it on the other side that you didn't replaced. and then drive it.
Old Sep 5, 2011 | 01:18 AM
Tigrpawz's Avatar
Tigrpawz
Originally Posted by master tech
Welcome to DF
Thank you for the welcome and reply. I still do have the old one. I will put the old one on the drivers side. I will post an update.
Old Sep 5, 2011 | 10:08 AM
NHWheelin's Avatar
NHWheelin
it is also possible you got a bad hub. I have seen this happen many times on different make and model cars. Matter of fact one of my friends went threw 4 "new" hubs before he got a good one
Old Sep 5, 2011 | 03:18 PM
master tech
It always possible.
Old Sep 5, 2011 | 05:26 PM
Tigrpawz's Avatar
Tigrpawz
I assume that the "new" hub is faulty. The whine was still present with the new hub. I decided to do an experiment.
I removed the driver side hub and pit it on the passenger side... I then put the old hub on the drivers side. Now the whine has shifted sides. Now I must turn to the left to stop the whine. I should be getting another "new" hub tomorrow.
Old Dec 5, 2011 | 09:45 PM
Tigrpawz's Avatar
Tigrpawz
After going through 3 "new" hubs, the problem is still there. I have checked everything I can think of... I guess I need to put it in the shop.
Old Dec 5, 2011 | 10:21 PM
hydrashocker's Avatar
hydrashocker
So did you replace both hubs with new ones then?
Old Dec 5, 2011 | 11:00 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
it could be the hub on the other side . . .
Old Dec 6, 2011 | 11:42 AM
Tigrpawz's Avatar
Tigrpawz
I only replaced the driver's side hub.
The hub I figured to be bad is on the driver's side. When going 30 plus mph with the wheels straight, you can hear the whine. If you turn the wheels to the passenger side (right side), the while is louder... if you turn the wheels to the left (driver's side) then the while almost goes away.
