need help with this trans rebuild
Old Sep 23, 2011 | 05:55 PM
hydrashocker's Avatar
hydrashocker
Don't wanna highjack the thread but may I ask how to identify the model of my tranny? I to have a 99 5.9 4x4.
You have a 46RE trans. But there are stickers on the passenger side, and also a stamp on the drivers side just above the pan mounting surface facing out.
99go<----- Your transmission is a 42-44RE
Torqued<---- Have you tried this?
Disconnect the electrical connector on the drivers side, shortly behind the shift linkage. (should be like an 8 pin connector) Take the truck for a drive. Bear in mind, you will not have ANY automatic function AT ALL. You will have to shift each gear manually. (and o/d will never engage.....) If the trans actually shifts this way, replace governor pressure sensor and solenoid. The other thing you could try is the transmission output speed sensor.
Old Sep 23, 2011 | 08:09 PM
torqed's Avatar
torqed
Not yet im about 3.5 hours away from home but i will tonight or in the morning
Old Sep 23, 2011 | 10:01 PM
hydrashocker
Try it first.
The reason I ask is because if it acts fine then it is electronic, not hydraulic and that is good. Remember you have to shift manual like a manual transmission because you will not have any automatic shifting because the PCM will be unincorporated.
Old Sep 29, 2011 | 10:44 AM
torqed's Avatar
torqed
Hydra i never did get a chance to unplug that eight pin connector but i will this weekend. By the way do you have another link were i can download that a518 rebuild video that gobble had posted? The sit that is in the faq section say's
Old Sep 29, 2011 | 10:45 AM
torqed's Avatar
torqed
Hydra i never did get a chance to unplug that eight pin connector but i will this weekend. By the way do you have another link were i can download that a518 rebuild video that gobble had posted? The site that is in the faq section say's it has reach its limit on bandwidth "33mb". Just wondering because that video seems very usefull
Old Sep 29, 2011 | 06:01 PM
hydrashocker
Yes I have the PDF for the tear down on the 46RE. Actually I have a few things. I don't have the video, it's like 800+ megs!
Now are you talking in this link: http://pwp.att.net/p/s/community.dll...pid=404015&ck=
because it looks like everything is still working?
Old Sep 30, 2011 | 12:34 PM
torqed's Avatar
torqed
Ok got the video downloaded last night. It was a pain but only 282mb im going to try and upload it when @ putlocker.com when i get a chance. Should make it easy for others to download
