Im so confused and need help from the masters
Old Oct 19, 2011 | 11:35 PM
  #21
RollerRed's Avatar
RollerRed
Oh fun...I was wondering why I had all these options for a 98.
How do I order a build sheet?
I did look under the rig and it has the same size tires I have on, 31x10.5R15
Old Oct 20, 2011 | 12:37 PM
  #22
laz45's Avatar
laz45
Compnine.com...
EDIT...nevermind that,I just checked and it and got this....
These types of announcements don't come easy, but effective immediately Comp Nine will be closing its doors permanently.
Thank you to everyone that helped keep the site going and for allowing Comp Nine to serve the community for so many years.
Please contact service@compnine.com if you have any immediate concerns.
That sucks....
Old Oct 20, 2011 | 03:06 PM
  #23
hydrashocker's Avatar
hydrashocker
The 1998 came with 31 10.5 15's and also 235/75/15 tires. Seeing that you have a 31 as a spare, and that if you read the tires build date you can most likely concur that your truck came with that size. That being said, you need to calibrate your instrument cluster. You run through the test over and over and try to place your indicators to the right spot as referenced by the reset notes as close as you can. Then see how far off you are with a GPS. If you are still off then get a tuner and have fun until you get it on and enjoy the performance it gives you.
As for a build sheet, go to our DIY sticky at the main page here in the 1st generation Durango section and click on it you will find your information. This first one's on me: https://dodgeforum.com/forum/1st-gen...wers-faqs.html
Or you can go to a Dodge dealer (parts) with your VIN# and they can print you off a build sheet.
Old Oct 21, 2011 | 10:50 PM
  #24
RollerRed's Avatar
RollerRed
Actually I found the sticker on the drivers side door says 235...so I am guessing that the P/O put 31's on it later and just switched the spare.
But I keep finding Canada symbols everywhere I look...Did they get a 5.9L and the AWD transfer case in 98? Also how can I tell if I have 4 wheel abs or 2 wheel? If I have all these other goodies on here shouldn't I have 4 wheel abs?
Old Oct 22, 2011 | 08:40 AM
  #25
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
not necessarily, 4 wheel abs was an extra option
also i know that my truck came from the factory with 31 inch tires, im pretty sure my door stick says that it came with the 235s also (i am not home to confirm what the sticker says right now tho)
Old Oct 22, 2011 | 11:17 AM
  #26
RollerRed's Avatar
RollerRed
Well I sure hope I do...how do you check?
Old Oct 22, 2011 | 11:40 AM
  #27
Radar696's Avatar
Radar696
When you open your driver's door you will find a sticker near the bottom of the door.
Mine also list the tires as 235/75R-15 and I'm sure that my truck came with 31/10.5-15's.
I'm sure of this because when I use my wife's GPS unit the speedo is dead on.
My truck also has just the 2 wheel ABS.
There are no sensors on the front wheels.
Oddly enough though one of the front hubs must have been a salvage because it has a wire in it that has been cut off.
Old Oct 22, 2011 | 05:41 PM
  #28
laz45's Avatar
laz45
I just went outside and looked...Same as sharp and radar
The door sticker gives info on 235x75xr15 with 15x7 rims..
But I know mine came factory with 31.5x10.5x15 with bigger rims..The build sheet also contraindicts the sticker...
I have the same GPS match as radar does...accurate, so whatever calibrations it's had were probably factory.Guess I should keep that in mind if I repair anything tied in with speed sensors or gauges etc...still on a learning curve with this one.....
Old Oct 22, 2011 | 06:47 PM
  #29
shrpshtr325
THE ULTI-MOD
to check for ABS you can call the dealer with your vin and they can tell you, or go to dodge.com/owners and there is a contact link, click it and send your VIN and they will email you back in a couple days with a full build sheet
Old Oct 22, 2011 | 11:58 PM
  #30
hydrashocker
All the 1998-1999 Duragos all came with the 235 on the drivers label because that was standard, however dealer options are different then standard and that is what decides the tire and gearing combination. Take 2 seconds out of your life and get the build sheet I told you to get and that will prove what I told you and clear your thoughts of what you think could be.
Most likely your truck is Canadian, and that means other options could be different, however I have NEVER seen an AWD in a 1998 period. If someone did swap it then it is not factory.
