03 Druango transmission Fail
Old Oct 22, 2011 | 02:03 AM
mkookie4's Avatar
mkookie4
Default 03 Druango transmission Fail
My transmission has a clinking noise inside it when it is put in gear and it wont go in to gear, when in park it rolls. do i need a new transmission??
Old Oct 22, 2011 | 09:06 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I'm guessing you have a 4.7 with a 45RFE transmission. Have you had any service done to the transmission?
Old Oct 23, 2011 | 12:08 AM
hydrashocker's Avatar
hydrashocker
No he has a 5.9L and a 2003 so he has a 46RE transmission. Could be the transmission shifter cable could be out of adjustment. Ensure the cable is in fact adjusted correctly then diagnose an internal failure or electrical.
Old Oct 23, 2011 | 12:18 AM
master tech
Sorry. Okay then either cable is off or the park paw rod had snapped off inside the transmission causing the transmission not to hold in park.
