Sputtering, Idle Jumping, occasional check engine light
I have a 1999 5.2L 4X4 Dodge Durango and lately it has been sputtering and hesitating a lot, it has 241,XXX miles on it. In the past seafoam has always fixed the problem but now it doesnt seem to make a difference. It started sputtering really bad and the check engine light came on, it stayed on for a few days and went away it will come and go. As of right now the light is off, and it did sputter while coming down my road. Then when i was letting it idle in my driveway it will idle at 6-700 rpms and about every 30 seconds it will jump up to 1000rpms for a second and go back down to idle.
I thought the TPS sensor was going bad at one point because the rpms would drop when i let off of the gas while driving and go right back up to were they were but it hasnt done it in a while.
With that check engine light you should be able to get some codes, that would help with the diagnosis. But just by the symptoms, it sounds like a vacuum leak. The leak makes it run lean and sputter-the lean condition is compensated for by adding fuel-RPMs increase-IAC closes to reduce the RPMs..... The codes will probably be for a misfire as it sputters, but there maybe something else for the Evap system. to get the codes; put the key into the ignition, then turn it to ON-OFF-ON-OFF-ON and leave it on (don't go to start in this sequence) the codes will be in the odometer window.
Hmm, this procedure worked on my old '97 Dakota. I guess they changed it up for a few years, but I thought Dodge always had a way to retrieve codes without a scanner by cycling the ignition, switch holding the odometer reset or some combo to get the CEL to flash the codes before the digital odo.
This is the procedure; it should be the same for the Durango. (Pre '97 used the flashing CEL) From dakota-truck.net
How to get the codes on a 1997 Dakota:
Put the key in your ignition and turn it to the "on" position three times. (Insert key, on, off, on, off, on). Leave it in the on position. The first trouble code will be displayed on your digital LED odometer. Quickly cycle the key again (off, on) to display the next code, and just keep cycling the key to get the remainder of the codes.
How to get the codes on a 1998-1999 Dakota:
Depress the trip reset and trip/odometer switches, and, while holding them, turn the ignition to ON/RUN, and wait about 5 seconds. This sends the car through a short self-test sequence that lights all segments of the odometer and shift selector read-out (where applicable). It will then display the stored error codes.
Trending Topics
