Sputtering engine solved
Old 11-11-2011, 08:08 PM
jetuco's Avatar
jetuco
jetuco is offline
Thumbs up Sputtering engine solved
Hey guys, I have lived with this issue for 3 years. After start up my 99' 5.9L would idle fine, then after 5 min it would start to idle rough and sputter and sometimes stall. Then after 3 mins of that it would smooth out and run fine. It happened mostly after sitting for more than 30 min. I have long suspected the pre-cat O2 sensor, but there were never any codes. I changed the IAC, TPS and did the full tune-up. My Y-pipe just rusted out on me and needed to be changed, I elected to change the Cat converter and both O2 sensors as well. (Pipes change was a bitch BTW.) The problem seems to have been corrected and I"m 99% sure it was that pre-cat O2 sensor. Just passing along some info , hope it helps someone else.
Old 11-12-2011, 12:06 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
Thank you for the update.
Old 01-10-2012, 06:19 PM
dompie99's Avatar
dompie99
dompie99 is offline
Good day y'all,
I had the same issue on my 3.9L, the complete tune-up was done on Oct 2011, distributor cap and rotor, wires, Ģspark plugs, TPS, Idle motor, Oxygen sensor (after the muffler) cleaned the Throttle Boddy and still had the same thing, sputtering after 3 min. and get back to normal after another 2 min.
I replaced the Oxygen sensor (before the muffler) and the issue went away. It was replaced last monday and three days later (today) it doesn,t do it anymore. PLUS, the gas mileage got better. Cheers to yeah all...xx
Old 01-10-2012, 10:05 PM
that_guy's Avatar
that_guy
that_guy is offline
I know this is off topic but, holy $hit, you have a v6 durango!? I've never seen one with a v6
Old 01-11-2012, 12:17 AM
RollerRed's Avatar
RollerRed
RollerRed is offline
I did always wonder why when I went to rockauto that they listed the 3.9L. I thought it was just a mistake...
Old 01-11-2012, 08:41 AM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
yea they made a durango w/ the 3.9 for 1 year iirc
Old 01-11-2012, 01:18 PM
otgarzā's Avatar
otgarzā
otgarzā is offline
*taking notes* ive always wondered if anyone had the v6 now i have stumbled upon one lol.
Old 01-11-2012, 01:25 PM
srch4me's Avatar
srch4me
srch4me is offline
holy **** i never thought i would actually see someone who owned one! lol
Old 01-11-2012, 02:07 PM
that_guy's Avatar
that_guy
that_guy is offline
I read somewhere once that they made less than 100 of them with the v6. (math time) So, out of the over 700,000 1st gens made 99.99985714285714% are v8s
Old 01-11-2012, 02:19 PM
otgarzā's Avatar
otgarzā
otgarzā is offline
Oh yeah!
Quick Reply: Sputtering engine solved
