Possible tranny issue
So I have had the D for about 3 months now and since I bought it I have noticed that second gear is real short. It shifts from first to second no problem but it is in second for literaly 2 maybe 3 seconds then into third. If Im getting on it with wide open throttle it will stay in second longer. Im not sure what the service record is on this D and was planning on doing a fluid and filter change. So my question is, is there cause to be concerned with the way its goes threw second gear or is that normal?
Try a throttle Valve cable adjustment.
https://dodgeforum.com/forum/2657572-post4.html
with some pics and more epx here:
https://dodgeforum.com/forum/2652744-post7.html
Cool. I will try the TV cable adjustement this weekend and will double check the fluid level. I checked it when it was new and the level looked good as did the fluid.
I will have to steal the D from my GF and take note of the speeds when it is shifting along with the RPMs.
As always thanks for the input
