Question about 4wd lights on dash
Old Jan 11, 2012 | 11:26 AM
mvoss2576's Avatar
mvoss2576
Question Question about 4wd lights on dash
This might be a stupid question... but it's one of those little things.
I have a 99 with the 2wd/4wdPT/4wdFT/4L option.
Here's the lights that show up in the respective positions
2wd - no lights
4wdPT -4 wheel Part Time
4wdFT -4 wheel Full Time
4L - 4 Wheel PART time (This is the one I am questioning..)
I would think 4L should show as 4 Wheel Full time??
Old Jan 11, 2012 | 12:28 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
nope 4L is a part time gear, the front and rear drive shafts are locked together, and the gearing is reduced, 4L gives you a top speed of like 35 or 40 in OD, and is designed to give you more power at low speeds in low traction situations (example: pulling a boat up a slipery boat launch)
you should NOT be driving in 4L unless you are in one of those high power low speed, low traction situations.
Old Jan 11, 2012 | 03:30 PM
RollerRed's Avatar
RollerRed
+1 on that...
The front and rear wheels also turn at different speeds. If you try to drive on dry roads with it on you will blow the TC.
Old Jan 11, 2012 | 09:22 PM
mvoss2576's Avatar
mvoss2576
Thanks for the clarification, and no, I wasn't even thinking of 4L on a dry pavement. I used it the other day when I cut a tree down and had to drag the trunk through a field that had loose soil... 4L was perfect for it.
Old Jan 11, 2012 | 09:38 PM
mikeismadness's Avatar
mikeismadness
Haha did the durango rip it through the field good? Least it dash 4x4 lights work...mine don't
Old Jan 11, 2012 | 10:08 PM
mvoss2576's Avatar
mvoss2576
Heck yeah! Started in 2wd until the rear tires started to spin, so I just stuck it in 4L and it pulled it with no problems at all. I was actually very impressed.
The 4wd lights are the only ones I want to see on my dash.. I was tired of the ABS/Brake lights, and I despise the low fuel light. LOL.
Old Jan 11, 2012 | 10:21 PM
mikeismadness
Lol I despise low fuel lights myself
Old Jan 11, 2012 | 10:50 PM
shrpshtr325
THE ULTI-MOD
i despise all dashboard lights (i dont have 4x4 lights in the instrument cluster, i have them on the electronic switch) however i avoid the low fuel light by filling up when it hits 1/4 tank left.
Old Jan 11, 2012 | 10:56 PM
mikeismadness
I don't think my durango has seen 1/4 tank since I bought it lol. I feel like I'm gonna run outta gas if it even gets close to 1/4 tank
