Rear wiper switch
Old Jan 22, 2012 | 07:03 PM
moparman_2004's Avatar
moparman_2004
Default Rear wiper switch
On my 99 the rear wiper only worked if I put the switch to on and pushed it in but then it squirted and wiped together it won't just wipe so I replaced the switch and it still does it so I'm at a loss as to what could be causing it ti do this
Old Jan 22, 2012 | 07:10 PM
TurboStixx's Avatar
TurboStixx
Possible fuse by chance? I am not sure but it may be that wiper fluid adn wiper at same time might be on a different fuse than just wiper by itself. Let me go grab my service manual and take a look for ya
Old Jan 22, 2012 | 07:18 PM
TurboStixx's Avatar
TurboStixx
There are not 2 seperate fuses from what I can see. Maybe the switch is a dud or just not getting the correct contact?
Old Jan 22, 2012 | 07:28 PM
moparman_2004
well i thought it might of been the switch but what are the chances i replace it with another and have the same problem i would of liked to look in the service manual but mine have not gotten here yet but is there a relay in there soem were or a resister setup somewere idk im lost
Old Jan 22, 2012 | 10:53 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
there is a 98 factory service manual available for download as pdf files in the FAQ thread if you would like to download it.
im going to ask the dreaded question, do you have any other electronic problems??? they will likely seem unrelated
Old Jan 23, 2012 | 12:08 AM
moparman_2004
ill mess with it some tomorrow but nope this is the only problem that i have with the vechical once i get it fixed all will be all good
Old Jan 23, 2012 | 09:52 PM
hydrashocker's Avatar
hydrashocker
Could be the motor or wire connection. I think the resistor is inside the motor harness.
Old Jan 23, 2012 | 11:23 PM
moparman_2004
Ok thanks anybody have another one that's known good they may split with or have more suggestions but I'll grab another motor and see what happens
Old Jan 24, 2012 | 05:56 PM
hydrashocker
Make sure you only grab a motor from a 1998 or 1999 as they changed them (I think) in all the other years.
