Tdc
Old Jan 28, 2012 | 12:35 PM
Andreas2k10's Avatar
Andreas2k10
Default Tdc
Played with the D a little and see the mark on the pulley not lining up exactly with the TDC mark on the engine block.
it is off to the driver's side by a couple of marks on the engine block.
Good? Bad? and IF bad...what to do.
Also looking at that pulley with the mark it seems to wobble a little. Checking it and it is not lose or movable.
(Is that pulley called the harmonic balancer?)
Old Jan 28, 2012 | 10:37 PM
master tech's Avatar
master tech
Site Moderator & Tech
How is the durango running first of all. 2nd you do use a timing light to check the timing. You need a scanner to read the dist for sink timing range.
