Coil
Old Feb 9, 2012 | 05:33 PM
Russ50's Avatar
Russ50
Default Coil
I have a 1998 Durango 4X4,,,,, Has the 5.2 eng in it,, I ain't getting any juice to the coil an all my fuses are good,, Can anybody tell me where a fuse could be or where the wire at the other end can be at,, When I turn my key on I don't have juice going to the coil an when I crank the motor over I don't have juice going to the coil,,
Old Feb 9, 2012 | 05:57 PM
rollin_99's Avatar
rollin_99
Without the codes, my guess would be the Crank Position Sensor.
Have you checked the ohms at the CPS when cranking it?
Old Feb 9, 2012 | 06:23 PM
Russ50's Avatar
Russ50
I just put a new crank Position Sensor in it an still not getting juice to coil,,,
Old Feb 9, 2012 | 06:32 PM
rollin_99's Avatar
rollin_99
Check the ohms on the Distributor Ignition Pickup. But having the codes would narrow it down.
Old Feb 9, 2012 | 07:24 PM
rollin_99's Avatar
rollin_99
Try this to test the Automatic Shut Down RELAY......
http://www.mediafire.com/?oomtinmdlw2
full pdf link.
http://www.mediafire.com/?53f6w4a6wme00
Old Feb 9, 2012 | 07:32 PM
crawlin95's Avatar
crawlin95
crank sensor and hall effect sensor wouldn't cause no power to the coil that could just cause the pcm not to send a ground to the coil to fire it. need to check asd relay to see if it clicks on also see if your getting power to the fuel pump and injectors.
Old Feb 9, 2012 | 07:55 PM
rollin_99's Avatar
rollin_99
hehe, When i read "juice", i thought he meant spark. doh!
Old Feb 9, 2012 | 08:03 PM
Russ50's Avatar
Russ50
I don't know how to give any codes at all,, an I will check out about the shut down,,, Thanks guys,, Sure hope I can get er running cause now I don't have anything else to drive,,
Old Feb 9, 2012 | 08:19 PM
Russ50's Avatar
Russ50
lol,, yea I hear that rollin 99 lol,, I not getting ecl. at the 2 wires that plugs into the bottom of the coil,,lol,, How is this,,,lol,,
Old Feb 10, 2012 | 07:42 AM
Russ50's Avatar
Russ50
Hey crawlin95,,,,, I checked to see if I was getting power to the fuelpump an injectore an I am not, My gas gages won't go up to show how much gas is in the tank I put 7 gallons in it so I know the gage should go up from the bottom of emty mark,, Now about the clicking you talking about is a VERY big prob for me, I am deaf an won't hear the click noise,, Can ya tell me where the click will be comeing from so I can put my hand on it then I could feel to see if I am getting the click,,, An alos to all,, I want to thanks ya for answering me back an sure hope nobody gives up on me,,
