Old Aug 6, 2015, 01:29 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting
Print Wikipost
No Low Beams! Please Help
Old Feb 12, 2012 | 02:30 PM
ihouse's Avatar
ihouse
Exclamation No Low Beams! Please Help
I have just recently put H.I.D. lights in my 2002 Durango. One of the headlights was acting weird and my dad thought it was something wrong with the connector on the headlight kit so he was messing with it and he plugged it in backwards and now my low beams don't work at all. Even if I plug in my stock headlight only the high beams work. The fog lights also still work. For now I've been only having my high beams on with the headlights tilted down. I cant find anything that was fried at all. Please help
Old Feb 12, 2012 | 04:17 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
check fuses in both the door jamb fuse box and the PDC under the hood, there are labels telling you what each fuse is for on the covers to both boxes
Old Feb 12, 2012 | 07:56 PM
ihouse's Avatar
ihouse
I already checked all the fuses and relays and there is nothing for headlights.
Old Feb 12, 2012 | 09:02 PM
that_guy's Avatar
that_guy
what about the hidden fuse box that is behind the normal one up under the dash, or did they do away with that with the 2001 update
Old Feb 13, 2012 | 07:06 PM
hydrashocker's Avatar
hydrashocker
I don't think that is installed in 2001.
Anyway, that is why I don't install HID, or any of that crap in the first place. Issues all over with that here. As for your problem, well could be a bad relay, fuse, or you just kissed the CTM good bye. Disconnect the battery and do a PCM reset.
Old Sep 15, 2013 | 11:26 PM
Mytquick87's Avatar
Mytquick87
I installed a bi zenon hid kit on my 2002 grand caravan but can't get the headlights to switch between high and low beams- any suggestions?
Old Sep 15, 2013 | 11:48 PM
PublicHair's Avatar
PublicHair
Revered wires I would assume. 9004 plus is the same as a 9007 however the pin layout is different.
For example the 9004 plug may have the ground wire in the center and on the 9007 the ground wire would be the bottom left.
Old Sep 16, 2013 | 12:20 AM
that_guy's Avatar
that_guy
