Old Aug 6, 2015, 12:12 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Blower Motor Resistor - Constant burn-outs
Old Jun 18, 2013 | 05:35 PM
  #21
BenDeutschman's Avatar
BenDeutschman
Angry Blower Motor Resistor Plug Overheating
A while back I had to replace the Blower Motor Resistor, and the Plug, since it had melted and fused itself to the Resistor. Now the new Plug is overheating, and I'm wondering if anyone has a solid answer as to the cause of this phenomena.
Old Jun 27, 2013 | 04:20 PM
  #22
ctad841's Avatar
ctad841
I received my new connector with the green wires and purple wires, you said you had to remove the cap to put the connector end of the wires in to it. how did you do that? and what is the small blue thing with the tiny holes on it? thanks
Old Jun 28, 2013 | 02:26 PM
  #23
BenDeutschman
I think what you are referring to is the back side of the Plug were you insert the wires in the Kit they sell you. The Blue part is a weather/moisture seal, and this style plug is supposed to be sealed by nature of its design when fully connected.
In terms of the wire supplied with the Kit, the Green wire is a heavier gauge wire than the purple wire, and which one you use, I would say depends upon what the O.E.M. wire gauge is.
I finally replaced the Resistor, Plug, and Blower Motor, so far, so good, but like one other person in this thread said, we'll see how long things stay good.
Old Jun 28, 2013 | 06:22 PM
  #24
moe7404's Avatar
moe7404
replace the OEM wire with OVERSIZE, just bypass it. and run it through a head light relay. had the same thing on a 82 ram with the A/C blower in the ignition switch burning up.
Old Jun 30, 2013 | 01:14 AM
  #25
BenDeutschman
Since the O.E.M. set-up is a five wire plug, and two of those power the blower Motor, I would figure the other three are the power in leads that correspond to the different Blower Motor speeds. So how would a simple Relay be able to provide varying fan speeds?
Old Jun 30, 2013 | 03:05 PM
  #26
moe7404's Avatar
moe7404
well i think my set up was different. but only the wires that are burning need a relay, and over size wire. but the wires still have to be able to carry the current. in my case only the switch was burning. look up ALL ELECTRONICS they should have the real heavy duty relays.
Old Jun 30, 2013 | 03:23 PM
  #27
WsW-WYATT-EARP's Avatar
WsW-WYATT-EARP
not trying to hijack the thread - but same issues.
front blower motor quit working, searched and found common issue - resistor. Replaced resistor and it worked. Couple days later it stopped - was warm and had A/C running on way home from work.
When i replaced it, I noticed the #2 wire on the connector was melted. The wires are the green more heavier wires.
So, I had wife find another resistor and figured I would get time this weekend to check deeper into it. I had to go drop the kid off this morning and the blower worked again??? I pulled the dash and all the wiring to the front blower motor control look good. The wiring on the back side of the resistor connector all look good and nothing melted.
I think I just need a new connector? I did not replace the resistor as it is working and don't want to go through 3 in a week, until I get a replacement connector.
This sound right? I am going to visit a pick and pull and see if I can find one - take the resistor as well for another spare.
Thanks for the info - internet is an amazing beast with issues like this!
Old Jul 1, 2013 | 05:51 PM
  #28
BenDeutschman
Default Dakota Blower Motor Resistor Plug
Does the Connector in your Dakota/Durango look like this?
By the way, you can buy these Plugs new from most Auto Parts stores, apparently they fry frequently.
Attached Thumbnails Blower Motor Resistor - Constant burn-outs-blowermotorharnessandplug-brightened_zpsd3bb4bde.jpg   Blower Motor Resistor - Constant burn-outs-blowermotorresistorplug_zps57076183.jpg
Old Jul 2, 2013 | 07:51 PM
  #29
WsW-WYATT-EARP
That is what my plug looks like and where it melted.
Old Jul 3, 2013 | 11:23 PM
  #30
BenDeutschman
Unfortunately, the images didn't appear, nor open when clicked on.
