Question for Durango experts 2003 4WD
Old Mar 26, 2012 | 11:08 PM
  #21
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
thank you hydra, i thought the axle going through the hub was important somehow.
Old Mar 27, 2012 | 06:44 PM
  #22
dolittle's Avatar
dolittle
Originally Posted by hydrashocker
That is an incorrect analogy.
Yes the base of the wheel bearing on a 4X4 is connected to the spindle via 3 bolts, however the wheel bearing is a 2 piece bearing set up. See the end of the CV Half Shaft inputs into the bearing through the center, then you have a main nut on the outside end. This main hub nut then presses the second and primary bearings together giving the wheel bearing pre-load and ensuring against it's separation. The rear end of the bearing is connected to the spindle. So you are incorrect in your analogy.
You are correct. I didn't think of that. I just glad the OP didn't have to do this it could of been a crash. Thanks for the heads up.
Old Mar 27, 2012 | 08:30 PM
  #23
hydrashocker's Avatar
hydrashocker
Your welcome.
I actually ripped apart a 4X4 wheel bearing assembly to see it they could be rebuilt, which I am sad to say they can't because of design.
