Tv cable adjustment
Old Mar 23, 2012 | 10:24 PM
mikeismadness's Avatar
mikeismadness
Default Tv cable adjustment
Ok so I attempted to adjust my tv cable today because on D, I can go WOT and I shift at 3,000 RPM. Now I could be wrong, but that doesn't seem right. So I figure I'd try to tighten up the tv cable but it didn't budge, I move the t retaining clip and pulled the black linkage toward the firewall, it moved slightly but it still seems loose and has 2-3 mm of play. What am I doing wrong?
Old Mar 24, 2012 | 06:07 AM
mikeismadness
Well after work I decided to tear into it. Come to find out the tv cable isn't even connected to the transmission, great. Think I have found the spot where it goes, but I can't get it to clamp down? Tips or tricks?
Old Mar 24, 2012 | 12:05 PM
mikeismadness
Does anyone have a schematic or diagram of where the tv cable is supposed to go?
Old Mar 24, 2012 | 01:59 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if you checked the FAQ thread you would find a link to a mediafire link for other durango manuals and information
inside of that folder you can see all the pdfs available, sorted by generation and then year if applicable, in the 1st generation folder you can find this file http://www.mediafire.com/?4z89ndodf38txbr which explains the adjustment of the TV cable complete with pictures
Old Mar 24, 2012 | 02:25 PM
mikeismadness
Ended up finding my Haynes manual, looks like I'm missing somethings on the transmission. Walked out this morning and wala, someone busted out my drivers window last night. Love my town....not
Old Mar 24, 2012 | 02:49 PM
lbzrango's Avatar
lbzrango
^^ had that happen a few times, isn't it awesome!
Old Mar 24, 2012 | 04:10 PM
mikeismadness
Thanks shrpshtr. White widow also gave me a few pics. It seems I'm missing some linkages for the tv cable. Love my town man, ridiculous
Old Mar 25, 2012 | 10:05 PM
hydrashocker's Avatar
hydrashocker
Go from a bad/missing TV cable linkage to a broken out window, not to mention the drivers side mind you. Somethings missing here and it smells like bad eggs?
Old Mar 25, 2012 | 10:53 PM
RollerRed's Avatar
RollerRed
So what exactly does this do when you tighten it? All of the cables on my TB are loose. Should I redo them all?
Old Mar 25, 2012 | 11:32 PM
master tech's Avatar
master tech
Site Moderator & Tech
All the cables should have some play ( Loose ). If the end of the cable at the throttle is broken. Then the cable needs to be replaced.
