trans not shifting
Old 03-25-2012, 04:22 PM
mrkinnamon's Avatar
mrkinnamon
mrkinnamon is offline
Default trans not shifting
i know there are some other threads out there but i still cant seem to fix my problem. ive got a 2000 durango 4x4 5.9L. i just replaced the governor pressure solenoid and transducer in the tranny. new trans filter. replaced the speed sensor on the trans. and im still have the issues. 1-2 will mainly just rev up to 5-6000rpm and just not shift. then when it does shift into 2-3 it just slips. it will rev up but not move. just has no power. ive adjusted the tv cable but it doesnt seem to be helping. and its only intermittent. PLEASE HELP!
Old 03-25-2012, 04:28 PM
WhiteWidow00's Avatar
WhiteWidow00
WhiteWidow00 is offline
Was there any metal at all on the magnet when you pulled the pan to replace the filter? Also, usually when it goes into limp mode (it sounds like what you're describing), it triggers an MIL and a hard code in the computer.
Is there a MIL illuminated in the dash or possibly an ABS/Brake combination on?
Old 03-25-2012, 06:01 PM
mrkinnamon's Avatar
mrkinnamon
there was extremly small amounts on the magnet. almost like powder. its not in limp mode because i know what thats like. ive replaced the pcm. there is no mil check engine or abs light on.
Old 03-25-2012, 07:02 PM
mrkinnamon's Avatar
mrkinnamon
Also, changing gears manually doesn't do anything..
Old 03-25-2012, 07:12 PM
Old_School's Avatar
Old_School
Old_School is offline
band adjustment maybe?
Old 03-25-2012, 08:33 PM
WhiteWidow00
Yeah, I'd re-adjust the front band because I read it again and it does sound like the band is too tight, that it is not letting 2nd gear disengage, thus causing it to slip going into 3rd. I'd also check adjustment of the rear band because this has been known to cause problems as well.
Make sure to torque the front band down to 72 in-lb then back off 2-7/8 turns, and for the rear band torque down to 72 in-lb and back off 2 turns.
Old 03-26-2012, 12:09 AM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Problem is that adjustment procedure has been updated a few times. It's better to drop the pan and manually see how much room there is between the clutch and the drum, 1/4 to 1/2 inches best when you pull down on the band.
Also check this thread: http://www.dodgeforum.com/forum/1st-...-problems.html
Old 03-30-2012, 07:02 PM
mrkinnamon's Avatar
mrkinnamon
still having the same problems. except my engine light came on today. p1756. says something about the gov pres sensor is too low or soemthing like that... I JUST REPLACED THAT SENSOR!
Old 03-30-2012, 08:04 PM
WhiteWidow00
No, silly goose.
P1756 Gov Press Not Equal to Target @ not15-20 PSI
Did you replace just the sensor or the entire governor pressure solenoid? There's a transducer (sensor) and then there's a solenoid. The governor pressure solenoid is not puting out the correct amount of pressure.
Old 03-30-2012, 09:06 PM
mrkinnamon's Avatar
mrkinnamon
hahha yeah i know what it was i was just being lazy. but yes, i replaced the black sensor/transducer and the solenoid..
Quick Reply: trans not shifting
