Help
Old Apr 5, 2012 | 04:14 PM
dodgefxr's Avatar
dodgefxr
Question Help
last february the tourque converter in my 99 durango went out I bought a used transmission and tourque converter for it because i was told if the tourque converter went out I would need a transmission. Now I've got the transmission ready and bolted up but when it is bolted in all the way I cannot turn over the engine but when the transmission is not bolted in I can turn the engine over by hand. The tourque converter is in all the way so what else would cause it.
Old Apr 5, 2012 | 08:22 PM
mikeismadness's Avatar
mikeismadness
Does the starter just click?
Old Apr 7, 2012 | 07:06 PM
dodgefxr's Avatar
dodgefxr
It clicks but it cannot actualy roll over
Old Apr 7, 2012 | 08:00 PM
mikeismadness
Have u maybe had the starter tested to make sure its good? Maybe with the transmission bolted in it has some extra pressure that a bad starter couldn't kick over. If not, I'd check to make sure the torque converter was all the way in just to make sure and also go over everything to make sure nothing is missing
Old Apr 9, 2012 | 04:29 PM
hydrashocker's Avatar
hydrashocker
Is the trans locked up? Maybe in the incorrect gear. Take off the linkage and check to see if it is actually in park or neutral.
Old Apr 9, 2012 | 11:22 PM
master tech's Avatar
master tech
Site Moderator & Tech
With the transmission bolted to the engine, Can you rotate the torque converter by hand to line up the torque converter bolts? If it doesn't rotate by hand, then the torque converter is not all the way back into the bellhousing.
