P0443 Plenum gasket
Old May 8, 2012 | 01:31 PM
majerus's Avatar
majerus
Default P0443
My 1999 Durango with a 5.9 started to throw P0443 code about 2 months ago. Around that time i took off the throttle body and decided to clean it a bit. While doing this I noticed that there looked to be oil in in the back of the intake. This seems to be indication of a bad plenum gasket. Since money was short i decided not to replace it at that time. Now i am trying to track down the p0443 issue. Could it be possible that the bad plenum is causing this code to be thrown? I have searched and have came up empty on linking the two together.
So far in trying to track down the code I have done a visual inspection of the hoses coming from the evap canister purge sensor. I looked under the durango towards the fuel tank to see if the hoses looked dry rotted. None did.
Old May 10, 2012 | 12:38 PM
majerus's Avatar
majerus
So after reading a lot more on the subject it is an issue with the purge solenoid. So my issue with the plenum gasket should not matter. While trying to understand what was wrong i noticed that both wires had voltage coming across them. The wire to the left (the red wire) has 4.07 volts when the truck is on and goes to 0v when the truck is off. The wire to the right (blue, green, sorry i am color blind so what ever so bare with me) had 14V when the truck is running 12V and with the key on. 0v when the truck is off.
Old Sep 17, 2012 | 10:39 PM
timandsue's Avatar
timandsue
sounds like a short in the wires somwhere, thanks though I am having the same problem. I think I am just brain dead
Old Sep 18, 2012 | 10:14 PM
master tech's Avatar
master tech
Site Moderator & Tech
I sent timandsue a few pages of a PDF file for code P0443. If you want them just ask.
Old Sep 19, 2012 | 08:16 AM
majerus's Avatar
majerus
If you have a few pages on this I would love to have a copy.
Old Oct 11, 2012 | 12:07 PM
r3024's Avatar
r3024
I would appreciate the pdf's if you can. Ronnie r3024@sbcglobal.net
Old Oct 12, 2012 | 10:26 AM
Matthew Guilbault's Avatar
Matthew Guilbault
Is there a way to post these .pdfs onlne so everyone can see them?
Old Oct 12, 2012 | 06:42 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
many of the PDFs are available for download in the FAQ thread near the bottom
