Turn signal issue.. Help!
Old 05-17-2012, 05:58 PM
Gus00's Avatar
Gus00
Gus00 is offline
Default Turn signal issue.. Help!
99 Durango,
Turn signal (either direction) blinks correctly for a bit then stays on solid. Can't find a relay, or any reference to a relay in the owners manual. Ideas?
Old 05-17-2012, 08:02 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
sounds like the multi-flasher to me, im not sure where it is on the 99 but im sure someone will chime in.
Old 05-19-2012, 01:53 AM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
Same place. Up high above the e-brake pedal. Square looking block.
Old 06-15-2012, 09:28 AM
Bimmer's Avatar
Bimmer
Bimmer is offline
I'm having similar issue. Blinks once then nothing. Relay is easy to find at O'Reillys but their $52. OUCH! Seeing if I can find other OEM sources. Rockauto has them for about $25 for an EFL-17 relay and I don't think they're that high a quality. Anyone have any good sources? ...ooops! Forgot to mention this is on my '99 w/5.2L.
Well now I have to correct my thinking. I just went out and pulled the relay and the Chrysler OEM number is cross-referenced on the Rockauto site for the EFL-17. For $25 I might just go ahead and figure a 50% is as good as it's going to get. By the way, the OEM number for the flasher is 56021915AA
Old 06-16-2012, 12:15 AM
IndyDurango
Should be about $10
Old 06-16-2012, 09:31 AM
Old_School's Avatar
Old_School
Old_School is offline
I paid 12 something for mine a few months ago at advance auto..
Old 06-16-2012, 12:42 PM
Gus00's Avatar
Gus00
Gus00 is offline
yep.. about $10 at CARQUEST.
Old 06-17-2012, 02:47 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
The older versions are located in the fuse panel at the bottom. Open the little dash panel door and it is at the bottom. In the later years they move it up behind the fuse panel.
Old 06-18-2012, 11:52 AM
Bimmer's Avatar
Bimmer
Bimmer is offline
Well that sucks if pricing is totally dependent on what region you live in. As I mentioned, O'Reillys wanted $52. I bought mine from RockAuto.com which is a significantly wholesale priced online auto parts dealer. I've bought a lot from them and saved a ton of cash. I'm wondering if you guys are talking about the old-style flashers that were made of aluminum. My relay is a very large cube-shaped relay that fits behind the fuse panel and access to it is waaay up near the top of the underside of the dash. RockAuto was the cheapest I found that cross-referenced the OEM Chrysler part number. Even NAPA wanted more than Oreillys. At any rate it should be here today or tomorrow. I'm not going to balk at having to pay $30/shipped.
I just called Carquest and the part was $32.31 so we're missing the mark here somewhere's friends.
Old 06-18-2012, 11:15 PM
Mechaniczman's Avatar
Mechaniczman
Mechaniczman is offline
doesnt oreilys match other local auto parts places prices? at least the one by me does.
Quick Reply: Turn signal issue.. Help!
