Overhead console HomeLink Lights
Old Jul 12, 2012 | 08:31 AM
  #21
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the trip issue may be about where you live, for me to go anywhere im driving at least 15 miles round trip, and 30 round trip is pretty common as well.
that said if you take that bulb into radioshack you should be able to match it to an LED if you want to they do stock LEDs (at least the one by me does)
Old Jul 12, 2012 | 11:25 AM
  #22
Compactc9's Avatar
Compactc9
I drive a 40 mile round trip to work every day, to me driving is just normal. The Dodge dealer I go to is closer to 30 miles away.
Old Jul 12, 2012 | 12:18 PM
  #23
MoparMan1991's Avatar
MoparMan1991
Originally Posted by Sooper
That's the stupidest thing I have heard on this forum yet. 10 - 1 it's not made by Toyota. The one you pulled out of your Durango wasn't even made by Mopar. It was made by the same manufacturers that make the Homelink components. Ever wonder why Homelink is in Fords, Mopars, Toyotas, Lexus...the manufacturers just contract to buy the stuff and put it in their cars.
Do what you want, I'm done trying to help you out.
Okay, I appreciated the help at the beginning, but it soon led to d-baggery. Thanks for the info you have provided though.
I used to drive 40 miles round trip to work daily also, but that was when I had a job.
Well I just remembered there was a toyota dealership next to the Dodge place thats just up the road a few minutes. I will probably stop there and see if they can find those bulbs for me.
Old Jul 12, 2012 | 06:41 PM
  #24
MoparMan1991
Okay so I went to dealership and the above mentioned part number isnt even close to the bulb. The closest match I could find from Toyota was 90076-04003. Its almost the exact same, just a little bigger. I had to pull out the Dremel and gring the base around the bulb down a bit to get the bigger socket to fit in the old hole. The bulbs are $3.32 USD each.
