2001 durango 4.7l won't start
Old Jul 28, 2012 | 10:39 AM
ElectricalHazard's Avatar
ElectricalHazard
Default 2001 durango 4.7l won't start
Hello all,
My durango will fire but won't start. We replaced the battery a few weeks ago. We were driving and it died at a light and wouldnt restart. It seemed like an alternator problem but everything electrical works fine. The windows still roll up and down very quickly and battery still hold a good charge. No codes show up when checked as well. Any help is appreciated.
thanks!
Old Jul 30, 2012 | 09:35 PM
topdogcustoms's Avatar
topdogcustoms
check your battery cables
Old Jul 30, 2012 | 09:37 PM
topdogcustoms
didn't mean to double post stupid computer
Old Aug 11, 2012 | 02:24 PM
ElectricalHazard
Default Checked cables and battery
So, I did a thorough check on the cables and they were good. I then took the battery out and had it tested. (mind you the battery is less than 2 months old)
It was severely discharged and took 60-90 minutes to completely recharge. Brought it home and put it back in, but it still won't start.
Old Aug 11, 2012 | 03:01 PM
dolittle's Avatar
dolittle
Check your fuel pressure (with a gauge) Check for spark. If no spark my guess would be crankshaft position sensor. If no fuel pressure probably fuel pump.
Old Aug 11, 2012 | 06:41 PM
hydrashocker's Avatar
hydrashocker
+1 dolittle
Finally could be a PCM, but I would go there yet. Do what dolittle stated first.
Old Sep 1, 2012 | 10:58 AM
ElectricalHazard
Default interesting
Sorry for no response, I had to go out of town. Just got back last night and decided to try to start the Durango this morning. It started, and ran for about 5 seconds then dropped in RPM's and died. Is that a hint in a any direction?
thanks for all your help!
Old Sep 1, 2012 | 11:46 AM
Duralude09's Avatar
Duralude09
sounds like fuel pressure. try turning the key on to let the fuel pump run and cycle it a couple times then try to start. if it starts then dies again. may guess would be that something fuel related
Old Sep 1, 2012 | 03:27 PM
ElectricalHazard
I replaced the camshaft and crankshaft sensor, still same issue so I am leaning towards fuel. On the hunt for a fuel pressure tester. Thanks so far for all the help!
Old Sep 1, 2012 | 03:35 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
did you check for spark? pull a plug wire and put a plug in it and hold the plug to the block watch for spark while someone turns the engine over.
if it has spark put a fuel pressure gage on it and see how much pressure you do or dont have
