Dodge Durango 2001 overheated
Old Sep 1, 2012 | 09:04 PM
cristian1967's Avatar
cristian1967
Angry Dodge Durango 2001 overheated
My durango upper radiator hose broke and the engine overheated. I finally got it to start today but is does not stay on and runs very rought. How I ?can probe if the head gaskets are damage
Old Sep 1, 2012 | 10:06 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I will move your post to the 1st Gen Durago section. You didn't state which engine you have.
Old Sep 2, 2012 | 06:00 AM
cristian1967
My engine is a 4.7L V8 and I am running out of idaes, first the car overheated, after i replaced the radiator hose that broke and refill the system did start and when it start missfire now sometime starts and someimes it does not. when it does start runs rough and the computer does not read any codes, how I can test the head gaskets?
Old Sep 2, 2012 | 07:28 AM
pkucan's Avatar
pkucan
You need to do a compression test on each cylinder. You can rent the tester from Advance auto or Autozone. Return it and get your money back.
Old Sep 2, 2012 | 08:08 AM
cornchewincowboy's Avatar
cornchewincowboy
If you are lucky your head gaskets will be blown.
If you are unlucky the heads will be warped, which is what I think has happened.
In my 60 years fixin' the locals cars and trucks I've realised that when the rad hoses blow with the hot Texas weather the engines die pretty soon and almost always warp the heads.
Old Sep 2, 2012 | 08:56 AM
Maxed's Avatar
Maxed
+1 I agree, The head gaskets are both probably blown and I would take the cylinder heads to a machine shop to be checked for being warped and cracks especially between the valves.
Old Sep 2, 2012 | 12:37 PM
cristian1967
Where I can buy cylinder heads for the 4.7 L engine (Durango). Any idea in the cost of the repair?
