P0442 Code
Old Sep 4, 2012 | 07:44 PM
melodytoinvent's Avatar
melodytoinvent
Default P0442 Code
P0442 Evap Leak Monitor Medium Leak Detected
Basically wondering if it's just a guessing game of where the leak is or if the code is specific enough that there's a general area to start looking at. As for symptoms...nothing haha I don't hear anything, truck runs and drives fine, everything works so I can't give ya much more than the only code that's showing up.
2001 Durango SLT 4x4 4.7L
Old Sep 4, 2012 | 08:57 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
could be as easy as a bad gas cap or as much of a PITA as replacing all the evap hoses under the truck and in the engine bay.
the most common cause is the gas cap, the #2 spot on the list of the series of hoses leading to the charcoal canister underneath the truck, if you did a search or checked the FAQ thread there is at least one DIY on this CEL code
Old Sep 4, 2012 | 10:54 PM
melodytoinvent
My bad. You reminded me that I looked this up on my phone last night but I wasn't of sound mind lol but I'll replace the gas cap, check under the truck and other places just to be safe and leave an update.
Old Oct 2, 2012 | 11:02 AM
Rawyzf's Avatar
Rawyzf
I just threw this code yesterday. So the search is on.
Question though: I replaced the fuel pump last week, and we had a hard time getting the filler tube hose off the filler when lowering the tank. Wondering if we maybe cracked that hose a little bit? Do you think that could cause this code?
Old Oct 2, 2012 | 04:38 PM
shrpshtr325
THE ULTI-MOD
its possible, also do a search in the FAQ thread there is a write up on evap leaks in there take a look.
Old Oct 2, 2012 | 09:47 PM
Rawyzf's Avatar
Rawyzf
Thanks! I read up on all the threads. Gonna do the usual gas cap replacement along with the hoses that go bad on the carbon box or whatever that was called.
Old Oct 3, 2012 | 12:14 AM
otgarzà's Avatar
otgarzà
My guesses will always be gas cap, hoses, leak detection pump...gas cap should be from dealer. Any other might crap out...thats just my thoughts tho
Old Oct 3, 2012 | 08:42 AM
Rawyzf's Avatar
Rawyzf
Will keep you posted, parts should be here today or tomorrow.
Old Dec 18, 2012 | 10:53 PM
melodytoinvent
Figured I'd just add to this thread instead of making a whole new one.
Ended up being a cracked hose under the hood which I fixed but now...
P0445 Evap Emission Sys Purge Ctrl Valve Circ Shorted
If it said leak somewhere in there, I would just go check hoses again but it doesn't and I can't right now anyway, so given "Ctrl Valve Circ Shorted", I'm lead to believe it's something other than just a leak, no?
BTW I am looking at other threads about this stuff, but like I said..can't go check anything right now so I'm just trying to get a head start and/or try to sum it down a little.
