parking brake pedal too hard
Old Oct 3, 2012 | 12:20 AM
otgarzā's Avatar
otgarzā
Default parking brake pedal too hard
Just changed the shoes and drums on the truck...wheel cylinders, springs...all the good stuff. The deal is that now my parking brake is a little hard. Should i bleed the system or is it normal for that to happen. Its my first time doin the rear brakes on a monster like this.
Old Oct 3, 2012 | 12:44 AM
cummingetit's Avatar
cummingetit
Parking brake should be mechanical, don't think bleeding will help. I don't recall exactly but there should be an adjustment on them. Could be the flat bar with what looks like a flat head nut on the ends (flat head as in it looks like you could turn it with a flat head screw driver). Did you have to cram the drums on or did they slip on easily?
Posted from Dodgeforum.com App for Android
Old Oct 3, 2012 | 05:10 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the parking brake is mechanical bleeding will not help.
if the drums are not dragging and are actuating properly the most likely explanation is that the parking brake was WAY loose before you did the change and now it feels like it should
Old Oct 3, 2012 | 07:12 PM
MontyJ's Avatar
MontyJ
If you changed the wheel cylinders, I would hope that you already bled the system. But, as the others said, the stiffer parking brake pedal would be expected.
Old Oct 3, 2012 | 08:59 PM
otgarzā's Avatar
otgarzā
How far should the parking brake go down? I know mine used to go down pretty far and i knew it would be a bit harder but not like it is now. And i havent bled the system because i only changed one cylinder still got the truck waiting for the other cylinder. Couldnt get the line off of it yesterday
Old Oct 3, 2012 | 09:00 PM
otgarzā's Avatar
otgarzā
And when i had to install the drums they didnt slide on nor did i have to cram them in. Just took a push or two to get them in.
Old Oct 4, 2012 | 05:55 AM
MontyJ's Avatar
MontyJ
Are you sure you assembled everything correctly and didn't bind up the cable? If so, wait until you get it all back together then test it. If the brakes are not dragging and the parking brake works, all is well as shrps said. If it is not working properly, double check the assembly.
Old Oct 4, 2012 | 09:14 PM
shrpshtr325
THE ULTI-MOD
i have no clue how to describe the expected range of motion on the brake pedal for you unfortunately, i wouldnt worry about it until you get it back on the road and find a dragging or other problem with it.
Old Oct 7, 2012 | 12:51 PM
otgarzā's Avatar
otgarzā
okay ill have a look this week. should have time to do the other cylinder and bleed the brakes all the way around. as far as i know the cable was alright on both sides but ill have a look
Old Oct 16, 2012 | 12:47 AM
otgarzā's Avatar
otgarzā
Everything seems okay now. Replaced the other wheel cylinder, bled the brakes, but the parking brakes seems stiffer than before replacing the brakes but it might just take some getting used to.
