Need new headlight housings again!
Old Dec 16, 2012 | 04:42 AM
  #31
that_guy's Avatar
that_guy
Originally Posted by MoparMan1991
Right.
As for my story, after having my headlights properly adjusted I absolutely love these 1pc Depo housings. They jiggle a little on bumps but for the quality of light i'm getting I can certainly live with it! I would highly recommend them to anyone looking to replace their OEM housings. Next, I need to either hardcore clean my fog light housings, or get new ones to match the clean look of the new headlights.
Yeah, I need to get new fog lights too. I tried restoring mine, but they're way too pitted to completely save. Glad those depos worked out for you.
Why does that website tell me I need to install a warning cancellation device when I don't ever recall a warning for anything bulb related?
You wouldn't need to, that's for newer vehicles that's computer can tell if bulbs are burnt out. They way you wire the hids only has a trigger relay that actually uses the power from the standard headlight socket and that relay has much lower resistance than a halogen bulb, so when the computer checks the resistance it thinks that the bulb is out. However since our computers don't do that, we don't have to worry about that.
Originally Posted by krupaeric
i will admit that i was wrong about the hid lumen strength, but my wifes vehicle is a 2011 subaru impreza and we bought it last year brand new from the dealership. and i had to replace the bulbs this past spring, which i went directly to the dealership to get because they were actuially cheaper.
and my education at R.I.T didnt teach me wrong. R.I.T is a world renound school for technology.
i coppied this off of the ny dmv website. after RESEARCHING.
(using projector beams on an un-equipped reflector car is illegal and blinds oncoming drivers. That special coating in projector beam headlights helps to prevent the light from blinding oncoming traffic in cars.) ie. (retro fitting stock housings)
(it is federally illegal to retro fit stock housing with projector beams.
projector beam headlights are specificily made with a non reflective coating. although the lens kits are available on the market today and available in stores and on websites, they are made for off road purposes only. they are not dot approved, they are not manufactured with the non reflective coating which is required for dot approval)
this is coppied off of a scientific america comparison test.
(What are the pros and cons of HIDs vs Projectors?
To me, projector lights in general don't throw out as much light as regular HIDs. Oncoming cars with projector lights don't put out as bright of light as oncoming HID vehicles.
Are Projector style lights really better than HIDs, or is it just that they are currently the "cool" thing to have because they are newer and look cooler?
Studies proved that hids put out just as much light as projectors, projectors are more focused on the road right in front of you, as where vehicles equiped with hids have a wider longer beam. which allows you to see the side of road, to watch out for those pesky critters and pedestrians. Compared to projector beams, which acuially in most states you can only have projectors on a high beam and not on both high and low. having projectors on highways and thru populated areas is illegal, except for on empty roads due to there blinding effect, most all projector beams are equiped with a single reflected low beam.
the beams lengths were as followed.
average hid high-156m
average hid low-90m
average projector high-140m
average projector low-60m
in our tests hid vehicles were rated- 8.5 out 10.
projectors were rated- 7 out of 10.
vehicle used-
2010 chevy impala
2010 ford mustang gt
2010 dodge ram 2500
2010 nissan titan )
i didnt copy the whole thing just some key parts i thought were needed for this discussion.
i hope this helps ppl when deciding what they want.
First I'd like to say once again that I'm not going after you in any way, I'm just trying to keep the information here accurate.
Plenty of things people do to their car are illegal. And projectors aren't going to blind other driver's if they're properly installed and aimed. That's because of the light above the cutoff being completely blocked. I promise that if you keep reading down that page you'll find that it says putting hids in halogen housings are illegal too, which it is by the way. I've never heard of this coating requirement before (honestly I think it is just legal bantering), but I can say that I did put UV blocking film on my headlights to prevent them from getting yellow over time. I'm assuming they're getting at the uv that can be produced by the electric arc, however all hid bulbs have a uv blocking material within the glass of the bulb, so I really have no idea what they're going on about.
And no, it is not illegal in any state to have projector headlights, in fact a while back there was talk of the federal government requiring all headlights to be projector type by 2015. Saying that most cars only have projector beams as high beams is about as far from accurate as possible. Most cars with projectors have them as low beams and have reflector high beams. This is because projectors have much better beam control than reflectors and don't glare into other drivers eyes as much because of the cutoff shield. Why else do you think most if not all high end cars have projector headlights? Projectors are simply better, even these new led headlights popping up are still using projector technology.
What it seems like is going on with those numbers is that the test was inaccurate and or biased. They probably used a terrible projector or maybe even a halogen projector with a pnp hid bulb in it. A well designed projector meant for HID bulbs will always outperform hids in a halogen reflector housing or any reflector housing in general hands down.
Here are some visual aids:
first 2 pics of each one are low beam, 3rd is high beam.
Ford F150 with stock halogens:
Same truck with pnp hids:
now with a MMH1 hid projector:
with a lexus LS460 hid projector:
To sum things up here, the MMH1 (which is what I have) is essentially a budget hid projector, while on the other hand the lexus lx460 projector is considered one of the best hid projectors out there. You can see that even the budget hid projector outperforms the pnps in halogen housings hands down for width, evenness of light, beam control/glare, and distance. Like a I said before, I'm not sure what exactly it was, but something was wrong with that test that rit did.
thats cool mopar man, glad you found something you like.
and (that guy) go to www.hidkitxenonlights.com.
what you wrote about hid kits having ionized salt gass is incorrect, as well as you saying that the 55w hid kits produce more heat than conventional bulbs.
the 35w and 55w kits produce siginificantly less heat than conventional bulbs.
and the 35w and 55w kits use xenon gass inside of them.
also the 55w 4300k kits produce the most light out of any other light source. in oem housings.
the kits are also german enginered. and made in germany. not an oriental made product.
there bulbs are guranteed to last 10,000hr.
Yes, HIDs do have ionized metal salts in them, that's essentially how they function.
Straight from wikipedia on hid lights. You'll find this same information on any other good site if you look it up.
High-intensity discharge lamps (HID lamps) are a type of electrical gas-discharge lamp which produces light by means of an electric arc between tungsten electrodes housed inside a translucent or transparent fused quartz or fused alumina arc tube. This tube is filled with both gas and metal salts. The gas facilitates the arc's initial strike. Once the arc is started, it heats and evaporates the metal salts forming a plasma, which greatly increases the intensity of light produced by the arc and reduces its power consumption. High-intensity discharge lamps are a type of arc lamp.
High-intensity discharge lamps make more visible light per unit of electric power consumed than fluorescent and incandescent lamps since a greater proportion of their radiation is visible light in contrast to heat.
I know wikipedia isn't typically thought of as a good source, but it actually has very good information on it.
55w hids do make more heat than halogen bulbs, which is why some people that put 55w pnp hids in their halogen housings sometimes end up melting their headlights. If you don't believe me feel free to look it up.
I'm not going turn this into a debate over hid kits either. There are plenty of fakes that claim to be german made or whatever. I'm not really sure of the quality of that kit, but it's not really relevant here.
Old Dec 16, 2012 | 12:40 PM
  #32
MoparMan1991's Avatar
MoparMan1991
I understand that, but why would a quality website lie to its potential customers?
Old Dec 16, 2012 | 01:55 PM
  #33
that_guy's Avatar
that_guy
I don't know, they probably just looked it up somewhere. Maybe other 99 Dodges had the bulb out warning thing.
Old Dec 16, 2012 | 11:36 PM
  #34
adukart's Avatar
adukart
Well they technically aren't metallic salts. They are the alkaline and alkali metals, first two columns of the periodic table, in ionic form. They would have to be attached to something else like Cl-, NO3-, ect. to be "salts". So that is mis-information since it is just the alkaline in there. I couldn't tell ya much more except how the temp ranged tells what energy level the electrons of this alkaline atom jump too. The fall back down is when light is emitted hence the different colors for the different wave lengths cause of the temp.
So as for moparman I would go with a lower temp range cause the more white/blue the light is I've noticed sucks in snow storms.
Old Dec 17, 2012 | 08:37 AM
  #35
that_guy's Avatar
that_guy
Yeah, I guess you're technically right about those salts. Stick with around 4300k that way you'd get the most light and in the snow you'd still be able to see since there is a slight hint of yellow in the light. If it's an issue to, you may want to consider some yellow bulbs for your fog lights too (halogens of course).
Old Dec 17, 2012 | 10:05 AM
  #36
that_guy's Avatar
that_guy
I was a bit skeptical about that company after looking at their site, because everything they're selling just looks like rebranded versions of cheap chinese hid kits being sold on ebay. I looked them up with the better business bureau and found that they have an F rating! BBB page on them. The BBB actually has an alert on them them saying that they consistently refuse to help customers after sending them the wrong parts, and refuse them their money back and they are advising people not to buy from them. The business apparrently doesn't even exist at the claimed address.
To answer your question moparman, they're clearly not a quality company.
krupaeric, I don't know what research you did or how you determined them to be good, but they're clearly a bunch of frauds.
Old Dec 17, 2012 | 04:39 PM
  #37
adukart's Avatar
adukart
Yeah I put in some really white phillips bulbs, I think it was the crystal vision, and noticed the snow thing immediately. Same with fog but I have some 55w tractor flood lights next to my fog lights that make up for it. So yeah I would go with more yellow on the fogs, helps you spot ice also.
Old Dec 21, 2012 | 12:55 PM
  #38
scomike's Avatar
scomike
Right.
How is the light brightness and pattern? I drive through a forest every day and in the dark need to see the Bambi's. the stock lights are the craps on my 02 Dakota.
Old Dec 22, 2012 | 06:41 PM
  #39
MoparMan1991
Well I have the silverstars in mine so the light is pretty bright from those alone. As far as clarity, they're excellent. The Light pattern is also fantastic. Nice straight beams unlike the Anzo housings I had before these. The only think I don't like is that the horizontal aim can't be adjusted but honestly they're pretty spot on. I did have a small issue with install though. One of the mounting holes must have been almost the same size as the screw head so the screw pulled right through the bracket. I had to tear the headlight out and replace the plastic spacer with .5" of washers, and also put a washer on the front of the hole. I should have just used a washer to begin with since the bracket was plastic. but other than that, I love the things. Maybe some day when the slush isn't so slushy i'll get a car wash and snap some pictures of it.
Old Dec 23, 2012 | 01:48 PM
  #40
scomike's Avatar
scomike
Do they have daytime running lights?
