Potential brake issues?
abs by the nature of how it works will INCREASE the distance required to stop compared to a GOOD driver who understands and is capable of properly modulating the brakes to prevent lockup (i am well aware that most people dont fall into this category)
that said, your issue is not normal, i know that mine stopped grabbing around the same time i replaced my front brake hoses (they collapsed internally), i have no clue if there was air in the system, or if the bad hoses were causing them to grab extra hard, so my first step if i were you would be to bleed the system.
I've never had any problems with my brakes grabbing when they were cold. Maybe the brake fluid is starting to break down. You could always try flushing the old fluid out with some fresh fluid.
Anyway, I'm kind of glad I don't have front abs. I really don't like computers interfering with my control over the vehicle. I was taught to do threshold braking. I don't mind having the rear abs since the back tends to lock up easily due to not having much weight over the back end.
apologies in advance for the hi-jack here
correct a rolling tire has a higher coefficient of friction before it starts skidding, however ABS reduces the pad pressure on the brake rotor by pulsing the brake line pressure, this reduces the average pressure and slows down stopping (makes it take longer), higher brake line pressure = faster stopping as long as the tires are rolling.
now all of this is assuming that the tire is ROLLING, as soon as you start sliding the tire it all goes out the window because the friction coefficient between the tire and the road becomes the dynamic number which is MUCH lower than the static number (similar to how you can use less brake pressure to keep your truck stationary at a light than you used to get it stopped).
