Problem with backing up
Old Jan 14, 2013 | 10:27 AM
danab242's Avatar
danab242
Angry Problem with backing up
I have a durango 2001 2 wd . When I back up it gives a slipping or like I just ran over something feeling . I just had lower and upper ball joints and tie ends replaced . I know I need a alignment .does anyone know off hand what this might be ?thanks
Old Jan 15, 2013 | 01:37 AM
go-part's Avatar
go-part
Former Vendor
Does this problem only occur when in reverse?
It could be a bad valve body or shift solenoid or a bad tcm unit.
Old Jan 15, 2013 | 01:05 PM
danab242's Avatar
danab242
Angry Backing up problems
When I am backing up . I fill like I ran over a hose . Does anyone know what this might be only happens when I back up .. Please help thanks just had both lower and upper control arms and ball joints replaced tie end rods too. I still need a alignment could this be the problem
Old Jan 16, 2013 | 11:48 PM
danab242's Avatar
danab242
Unhappy please help putting my durango into reverse
i have a 2001 durango 2wd . Had control arms ball joints tie end rods replaced. now when i put it into reverse it fills like i run over a hose. only does it in reverse . Has anyone ever had this kind of problem before. i have 160,000 replaced the rack & pinon at 135,000 please help me . tired of spending so much money for things that dont really need to be replaced thanks ..
Old Jan 19, 2013 | 05:37 PM
danab242's Avatar
danab242
Unhappy Rack pinion problems
Just had some work done on my 2001 durango.replaced control arms w/ball joints tie ends rods shocks, had rack and pinion replaced at 135,000 now have 160,000. My problem is when I am backing up my front end fills like I just ran over a hose then I hear a pop . Does anyone know what this could be ? Could it be the rack and pinion no leaks ..
Old Jan 20, 2013 | 09:33 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you do not need 3 threads about the same thing, i have merged them all together for you, also your description of the problem needs some work
Old Jan 20, 2013 | 07:10 PM
danab242's Avatar
danab242
Sorry but I was going nuts over this problem found out it was a couple of bolts that needed to be tighten thanks for your help..I use this car for transporting my grand kids to school and church I don't have a lot of money to be fixing it.. God bless
Old Jan 21, 2013 | 03:09 PM
shrpshtr325
THE ULTI-MOD
you omind sharing which bolts were loose in case someone else has this same problem in the future?
thanks
