Plz help 2001 durango 4.7l
Old Feb 14, 2013 | 02:50 PM
brooklynbetty's Avatar
brooklynbetty
Default Plz help 2001 durango 4.7l
I have to change the plugs and pcv, is there a trick to getting that pcv off? anything i should no before I start this mission? Im also going to replace the ignition coil module and the fule injectors maybe.... any advise or tips is very welcomed!
Old Feb 14, 2013 | 05:23 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
https://dodgeforum.com/forum/dodge-d...s-section.html
ill move this for you.
however there is not trick pcv is a simple twist lock pull out push in twist back, that easy.
plugs do them one at a time and dont remove more than one coil at a time cant mix up the firing order that way
dont waste your time/monle replacing the ignition coils on the 4.7, as there are 8 of them its a bit cost prohibitive to replace them.
replacing fuel injectors is also a waste of money unless there is a problemw ith them just keep using them until there is a problem
Old Feb 16, 2013 | 12:17 AM
brooklynbetty
Default nice
Hey thank you so much for your time! Im doing the plugs tomorrow, so when its cold she wont start right away and then idles kinda funny and theres a belt starting to squeal and i dont think its the surentine belt. Do you think after a tune up the plugs and the pcv that would fix the problem?
Old Feb 16, 2013 | 12:50 PM
shrpshtr325
THE ULTI-MOD
it is possible, the other potential issues inclued the IAC valve/motor and the TPS
Old Feb 18, 2013 | 04:33 AM
brooklynbetty
Default problem still remains......
So after everything i did i still have the starting problem.... Ill get those parts tomorrow, is there one I should try first?
Old Feb 18, 2013 | 08:06 AM
shrpshtr325
THE ULTI-MOD
the iac is the one that matches the symptoms closest,
also the eonly belt under the hood on these trucks is the serpentine belt
Old Feb 18, 2013 | 12:21 PM
brooklynbetty
would the crankshaft sensor be a possibility?
Old Feb 18, 2013 | 01:05 PM
shrpshtr325
THE ULTI-MOD
the crankshaft position sensor (cps) would typically throw a code or cause a hard/no start condition if it were bad so id say that is probably fine.
Old Feb 19, 2013 | 01:23 PM
brooklynbetty
ok kool ill pick one up today, thatnx
Old Feb 27, 2013 | 02:50 AM
davidcoderpc's Avatar
davidcoderpc
my 01 never through a code. i replaced it and 2 months later started dieying and not starting all the times and it did not throw and codes but went ahead and changed it cause it was warrantied and now it starts fine these things love crank sensors i been through 3 in a year and a half
