2001durango code p0420 & p 0700
Old Feb 20, 2013 | 08:35 PM
danab242's Avatar
danab242
Angry 2001durango code p0420 & p 0700
My car has this code p0420 & p 0700 what does that mean what kind of part am I looking for..
Old Feb 20, 2013 | 08:44 PM
Judd360's Avatar
Judd360
P0420 is bank 1 cat converter out of range and p0700 is a trans code probably caused by the restricted cat
Old Feb 20, 2013 | 09:30 PM
Old_School's Avatar
Old_School
P0420 1/1 Catalytic Conv Eff
You have two O2 sensors in your exhaust, one before the catalytic converter and one behind it. The computer compares the two and determines if the catalytic converter is working as it should. To get that code, you either have a bad O2 sensor (could be either one) or you need a new catalytic converter. I would change out both o2 sensors to be safe, reset the PCM and see if it come back.
P0700 EATX Ctrller DTC Present
WHEN MONITORED:
Ignition on and battery voltage greater than 10 volts .
SET CONDITION:
An active DTC is stored in the TCM. One Trip Fault. Three good trips to turn off the MIL.
POSSIBLE CAUSES
  • DTC present in the transmission control module
Sounds like the first code is triggering the second, correct the first and reset the PCM.
Old Feb 22, 2013 | 03:27 PM
danab242's Avatar
danab242
Default Oxygen sensor
Ok autozone says I have 4 sensors 2001 durango 4.7 2 wd . What is the right parts I need please if any can tell me thanks
Old Feb 22, 2013 | 04:24 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
1/1 is bank one sensor one, pre cat sensor on the drivers side if you actually have 4 sensors, but i doubt that you do, only the california emissions package had 4 sensors and unless you live in CA i wouldnt expect you to have that package
Old Feb 24, 2013 | 10:44 AM
danab242's Avatar
danab242
Smile P0420 code
Just had all 4 oxygen sensor replaced had to remove exhaust .now it's good to go .thank you for the advice .i love this forum.
Old Feb 24, 2013 | 03:20 PM
SmokinJoe02's Avatar
SmokinJoe02
How much $, if you don't mind me asking?
SJ02
Old Mar 1, 2013 | 07:20 PM
danab242's Avatar
danab242
Pick them up from auto zone costs 44.00 each had them installed for another 100.00
Old Apr 9, 2013 | 08:55 PM
JeeperDon's Avatar
JeeperDon
Why do people assume it to be bad sensors rather than a cat issue? I'm getting occasional P0420's, and the D's 97,000 miles tell me the cat(s) are old too, besides the sensors.
Old Apr 9, 2013 | 10:30 PM
master tech's Avatar
master tech
Site Moderator & Tech
Do you have a power steering switch on you engine? But if you do, inspect the switch. If it is leaking, the fluid will go thru the wire harness and first sensor the fluid goes too is the o2 sensor and then to the PCM.
