To Service or not.....
Old Feb 22, 2013 | 07:48 AM
SmokinJoe02's Avatar
SmokinJoe02
Exclamation To Service or not.....
Hi All!
I posted this to a couple of Mods, so please forgive the repeat!
I have an 02 Durango 4x2 Sport SXT with 178K. It's a 4.7, but don't know what trans it has. (Have to look to be sure) Never had the transmission serviced. (bad I know) However, it's running strong with no shifting problems at all. With the HD fan clutch install and the high revs when it's cold, I thought early on that there may be some slippage in 1st, so I added Marvel Mystery Oil's product to the trans.
What advice do you have on getting the trans serviced at this point? Do it or don't bother with it?
SJ02
Old Feb 22, 2013 | 04:14 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
being that you have the 4.7 that means you have a 45 or 545 rfe transmission, they are physically the same transmission, the difference is in the programing which controls it.
if you have having shifting problems the FIRST thing to do is to change the fluid and filterS yes plural, it will not hurt the trans regardless of mileage.
Old Feb 22, 2013 | 04:37 PM
Old_School's Avatar
Old_School
+1 on the above i just wanna add that i would quickly learn to have a NO ADDITIVES policy... unless of course you enjoy spending money replacing expensive sh*t....
Old Feb 22, 2013 | 04:42 PM
shrpshtr325
THE ULTI-MOD
yea +1 on the no additives, since you did put some in you MUST purge ALL the fluid out of the trans now before the additives destroy your clutch packs (anytyhing except ATF+4 going into that trans will wreak havoc on the clutches)
Old Feb 24, 2013 | 08:38 AM
SmokinJoe02
Thanks guys! I'll be making an appointment this week to get the trans serviced and purged.
SJ02
Old Feb 24, 2013 | 11:48 AM
shrpshtr325
THE ULTI-MOD
make 100% sure they do NOT FLUSH the trans, a flush uses chemical cleaners and high pressure and will damage the seals and cause problems.
Old Feb 24, 2013 | 11:52 AM
Old_School's Avatar
Old_School
SJ02
Please DO NOT allow them to talk you into doing a transmission flush.. I am talking about the high pressure one... those will kill a transmission quick... make sure they do a drain and fill only.. There is also a machine that they can hook up to your transmission lines that will collect the oil fluid and replace with fresh as the truck runs.. that process is okay just don't let them do the flush!
Old Feb 24, 2013 | 02:36 PM
SmokinJoe02
Thanks guys!
I'll go to Dodge and request the trans service with the do nots. Just to let you know, there are NO shifting problems at all currently.
SJ02
Old Mar 1, 2013 | 10:00 AM
SmokinJoe02
Went to Dodge and Oreilly's to get the parts and fluids to complete the trans purge/fill, spark plugs, and differential oil, etc. HOLY!! The trans fluid went up $4/qt in 2 years! $300 just in parts! Anyways, I'm well on my way and will take it to get serviced next week. I changed my mind and will take it to a garage that did my a/c and misc work on both my Dodges.
SJ02
Old Mar 1, 2013 | 11:47 AM
adukart's Avatar
adukart
Well ATF+4 is a better fluid than ATF+3. Fluids is somewhere you definitely should not be cheap in.
