99 5.2 4WD Durango rear wiper motor
Old 06-21-2013 | 06:11 PM
Hehatesmydodge's Avatar
Hehatesmydodge
Default 99 5.2 4WD Durango rear wiper motor
99 5.2 4WD Durango - rear washer fluid will squirt, nothing from motor however. No noise/vibration in switch when moved, no noises from motor itself. Any suggestions before I pay too much to have it replaced? *Also, thought the starter was bad, turned out to be the starter wire. Never encountered that before!
Old 06-21-2013 | 06:22 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Well, you're in the wrong section but I'd be taking off the panel on the rear hatch and start poking around to see if anything is loose/worn/chewed up in the way of wiring. You might be able to go to a junkyard and pull a wiper motor from another Durango or maybe even a Caravan with the same look rear hatch.
BTW, Welcome to DF!
Old 06-21-2013 | 06:33 PM
dhvaughan's Avatar
dhvaughan
welcome to df.
+1 on remove the panel and find the motor, unplug the electrical connector and with switch on, test for 12v on the wire. if you have power, and the motor doesn't work, then get a new motor from a junkyard, especially a u-pull (cheap), or a new one from rockauto or other.
Old 06-22-2013 | 12:26 PM
Old_School's Avatar
Old_School
i would do as stated above first.. if you dont have 12v in the back check the fuses. if that checks out move to the switch..
Old 06-22-2013 | 09:31 PM
dhvaughan's Avatar
dhvaughan
Originally Posted by Hehatesmydodge
i just noticed the user name of the original poster - hehatesmydodge. LOL.
Old 06-23-2013 | 01:03 PM
Old_School's Avatar
Old_School
I find that odd as well.... how could any true man hate a truck? Isn't a truck required in the man code?
Old 06-23-2013 | 01:20 PM
RockGuardedDak's Avatar
RockGuardedDak
He could very well like trucks, just not the Dodge. But IMHO, it's not a real truck unless its a Dodge!!
Old 06-28-2013 | 06:48 PM
Compactc9's Avatar
Compactc9
I've never had a preference between brands, just ended up always driving Dodges and have had good luck with them, both cars and trucks, and one aunt and uncle won't buy anything but Dodge (or Chrysler, same van) minivans.
Anyway, I have a spare 98-00 style wiper motor that I'd sell cheap... Also remember that 98-00 rear wiper motors will NOT interchange with 01-03 versions. With the new interior they added an intermittent rear wiper feature, and the plug on the motors is different, so if you get a motor from a 01-03 you'll be SOL.
Old 06-08-2014 | 09:14 PM
Radar696's Avatar
Radar696
Thank you for the extra input Compactc9.
My rear wiper has been acting up over the last 6 months or so and it actually quit right in the center of the window the other morning.
So I'm figuring that I'm going to have to dig it out of there and replace it.
I did get it going again after messing with it for a minute or two.
If I do go with a used one, I'll be sure to stay away from the newer models.
Although my rear hatch does have some Michigan cancer and if I replaced it with a newer hatch how would I go about that?
Would I have to replace the wiring harness with the one from the old hatch?
Quick Reply: 99 5.2 4WD Durango rear wiper motor
