tranny swapped
Old Sep 3, 2013 | 12:40 PM
98Durango5.2's Avatar
98Durango5.2
Default tranny swapped
i swapped the transmission on my 98 durango 5.2 from a junkyard transmission and finally was able to put it on yesterday. but am having a problem when i shift to reverse the engine dies out. has anyone have had this problem?
Old Sep 3, 2013 | 06:13 PM
that_guy's Avatar
that_guy
Does the odometer window change when it stalls? Does it stall if you go straight to drive? Will it keep running if you give it a bit of gas?
Old Sep 3, 2013 | 06:21 PM
98Durango5.2
once i switch to reverse it shuts off but if i quickly go N or D it stays on.
Old Sep 3, 2013 | 08:52 PM
that_guy's Avatar
that_guy
And it drives fine in drive?
Old Sep 3, 2013 | 09:33 PM
Old_School's Avatar
Old_School
Does it idle slightly rough? I just rebuilt and re installed mine and had a similar issue and found that the crankshaft position sensor got slightly nicked my the flex plate. How the flex plate got bent is beyond me but, since it pretty easy to get to the CPS with the right wheel and the wheel well removed i would pull it out and inspect it.. if it shows signs of damage then i would pull the flywheel cover off and inspect the flex plate...
If that does not do it then there is either maybe a loose wire or a bad sensor.. or i am afraid i would have to say there is a internal issue with the trans you just swapped.
Just a thought... the transmission guru around here is Master Tech. hopefully he will chime in here or you could PM him.
Old Sep 4, 2013 | 12:34 AM
98Durango5.2
thx Old school ill check it out, and it idles slight rough when i let go of the brake then shuts off in reverse.
Old Sep 4, 2013 | 11:23 AM
Old_School's Avatar
Old_School
Yea id bet its the CPS then... here is what mine looked like:
Old Sep 4, 2013 | 11:51 AM
that_guy's Avatar
that_guy
I accidentally pinched the wires on mine between the block and bell housing the one time I had my transmission off to change the freeze plugs, and that killed it.
Old Sep 4, 2013 | 03:14 PM
98Durango5.2
thx guys i let you know if that was the problem
Old Sep 5, 2013 | 02:41 AM
98Durango5.2
you were right Old_School it was the CPS, but now im having another problem it feels loss of power when i put i in d it won't move on its own i have to press the gas pedal a little harder. also it won't shift like if its in a higher gear?
