oil recommendation
Old Oct 13, 2013 | 10:36 AM
vako's Avatar
vako
Default oil recommendation
4.7 175,000 miles, which oil yous recommend? i also have ticking sound on 1st start of the day for about 15 sec , last time i did oil change i put on fram filter and I've been told 4.7 do not like fram filters, i bough mopar filter and i just need oil recommendation.
Old Oct 13, 2013 | 11:35 AM
AppelH's Avatar
AppelH
I use Mobil 1 5-30 full synthetic. Hard to pass up when they have a case on sale at Costco for $4.50/quart. The oil debate is one that will be going on forever, it's all personal preference.
Old Oct 13, 2013 | 11:49 AM
DyingBreed's Avatar
DyingBreed
I use Mobil 1 High Mileage FS 10-30 and a Purolator filter. Main thing is using correct weight oil and a good filter. I.e. anything but fram
Old Oct 13, 2013 | 12:06 PM
vako's Avatar
vako
soo i read on 4.7 manual it needs 5-30? soo, 5-30 or 10-30??
Old Oct 13, 2013 | 01:04 PM
AppelH's Avatar
AppelH
Someone correct me if I'm wrong, but I read that the first umber is like an initial start playing viscosity, and the second number is like an operating temp viscosity. Therefore, a 5-30 will be better if your running in colder tempo, and 10-30 if you never drop below say 30-40 degrees but have hot summers. 5-30 I think is generally the preferred all around weight but it depends on your weather
Old Oct 13, 2013 | 01:15 PM
AppelH's Avatar
AppelH
Don't know how "playing" got intomy post. Not ssupposed to be there
Old Oct 13, 2013 | 03:51 PM
DyingBreed's Avatar
DyingBreed
I have a 5.9 so I am to run 10W-30 unless outside situations as said fall into another range. Go by what the manual says. It should give you what weight you need based on climate. If it says 5w-30 run it. If it says 10w-30 run that. That being said choose whatever brand you are comfortable with. My only suggestion would be pick one you like and stick with it. Don't be the guy who runs whatever is on sale, changing brand to brand to brand.
Old Oct 13, 2013 | 04:12 PM
PublicHair's Avatar
PublicHair
I use 10w-30.
5w-20 tends to give me blue smoke out my ***
Old Oct 13, 2013 | 10:43 PM
RockGuardedDak's Avatar
RockGuardedDak
I use 5w30 all year round. gunna change to 5w30 synthetic this winter tho. This should help you decide. Dig through this website a little and read. He breaks down a lot of things about oil
Old Oct 13, 2013 | 11:12 PM
adukart's Avatar
adukart
5w-30 amsoil signature series all its life with amsoil filter, great compression yet at 174k.
