R/T out the Gate...
Old 01-03-2014, 11:34 AM
JeeperDon's Avatar
JeeperDon
JeeperDon is offline
Originally Posted by grimreaperblackDurango
NOw lets begin on the subject of HP; Where should I begin?
That answer is all over the forum. Get a beer, put on some U2, and have a go at some research.
  #22
Old 01-04-2014, 01:05 PM
grimreaperblackDurango's Avatar
grimreaperblackDurango is offline
OK I have a question about my heater, It doesnt seem to want to warm up and when it does it works just ok in town but the minute I drive on the highway it blows cold air again. Could this be that I need to replace the thermastat for one with a higher temp. on it or could it be something not so simple.
  #23
Old 01-04-2014, 02:06 PM
dxloat's Avatar
dxloat
dxloat is offline
Yes you need to replace the thermostat, yours is stuck open.
  #24
Old 01-04-2014, 02:36 PM
PublicHair's Avatar
PublicHair
PublicHair is offline
Or you're low on coolant. Had that happen a time or two as well.
  #25
Old 01-04-2014, 08:01 PM
AppelH's Avatar
AppelH
AppelH is offline
If the above two don't work, flush the heater core. Worked like a charm on mine after eliminating the previous suggestions as causes.
  #26
Old 01-06-2014, 03:42 PM
I replaced the thermostat and now there's white smoke coming from engine my guess is coolant that was spilled from gasket from not draining it right what do y'all think?
  #27
Old 01-06-2014, 04:58 PM
dxloat's Avatar
dxloat
dxloat is offline
If the smoke is coming up from the engine compartment then I would probably say yes it is just spill that needs to burn off and it should be fine. But if you are talking about out the tailpipe then thats a little more complicated.
  #28
Old 01-06-2014, 05:22 PM
I just washed off the excess coolant off the engine compartment and it's doing fine I'm finally getting hot air. Thanks for all the help D. F!
  #29
Old 01-06-2014, 07:32 PM
!!!code p0304!!! Cylinder 4 misfire what are causes and possible solutions
  #30
Old 01-06-2014, 08:05 PM
dxloat's Avatar
dxloat
dxloat is offline
I get that same one when its really cold and I let it idle for 10 min. or so to warm up. It only comes up a couple of times a year so I personally don't worry about it, just clear it and go. If it is persistent check the condition of the regular tune up parts cap, rotor, plugs & filters maybe try some injector cleaner.
Quick Reply: R/T out the Gate...
