My '03 Dodge Durango SXT 4.7L
Old Jan 7, 2014 | 08:01 PM
  #91
PublicHair's Avatar
PublicHair
I've had my durango in -5 degrees and it didnt nearly have that hard of a time starting and deff does not sound anything like that.
Looks like you got some inspecting to do. And a new battery to get..
Old Jan 7, 2014 | 09:39 PM
  #92
a_thomas8811's Avatar
a_thomas8811
So this sound isn't normal? I am just try to figure it out. I am planning on doing a oil and oil filter change this weekend after I get my paycheck. It just hard to track down the noise because I wear hearing aids so it is hard to find the noise by the motor.
Old Jan 7, 2014 | 10:13 PM
  #93
that_guy's Avatar
that_guy
I don't know much about the 4.7 so I can't really comment on what is and isn't normal, but is the correct oil (5w30 if I remember correctly) being used?
Old Jan 7, 2014 | 11:02 PM
  #94
a_thomas8811
I am thinking about picking up Castrol GTX High Mileage 5W30 Motor Oil, STP High Mileage Oil Treatment, and FRAM High Mileage Oil Filter. I am going with 5W30 in the winter then spring to fall I am going with 10W30.
Old Jan 7, 2014 | 11:09 PM
  #95
that_guy's Avatar
that_guy
I'm fairly sure you need to use 5w30 all year round in the 4.7
Old Jan 7, 2014 | 11:14 PM
  #96
PublicHair's Avatar
PublicHair
Oil is oil. Highly unlikely it fix his issue anyway..
Old Jan 7, 2014 | 11:16 PM
  #97
that_guy's Avatar
that_guy
10w30 has a higher viscosity when cold than 5w30 (that's what the 10 and the 5 stand for), and since the 4.7 does have pretty small oil passages, so it could be causing issues in these colder temperatures if 10w30 is being used instead of 5w30.
Old Jan 7, 2014 | 11:26 PM
  #98
PublicHair's Avatar
PublicHair
I use 10w30.
I also run 185 in my rear axle.
Oil is hardly causing his issues. He's got a loose lifter at least
Old Jan 7, 2014 | 11:38 PM
  #99
a_thomas8811
I might be taking it in later to have the guys look at it since I don't know much about the motor. It might not be cheap but it better to have it done right than guessing the problem and cause more damage. I want to get this ticking noise fix before I have the exhaust shop install straight pipes with 2.25" pipe to the y-pipes with 3" tips.
Old Jan 7, 2014 | 11:45 PM
  #100
AppelH's Avatar
AppelH
Have you had strait pipes before? For a majority of people, they are just obnoxiously loud and dont really sound "good". I drove my truck a grand total of 12 miles strait piped while working on my exhaust, and it got old before I got out of my driveway. And mind you, I was 17 at the time. Just a thought, most people don't leave it like that long term.
