towing capabilities
Old Mar 6, 2014 | 02:22 PM
ericcarr2000's Avatar
ericcarr2000
Default towing capabilities
Ok guys, I have a 01 Durango 4X4 that has the bigger 5.9 motor in it. My question is this, I purchased a 25 foot boat the other day and have yet to hook up to her. The boat weighs 5100 pounds dry, not sure about the trailer but I do know the trailer weighs around 1000 pounds, its an aluminum trailer. I had to rebuild my transmission a few years ago. Will my Durango be able to pull that kind of weight behind it ok? Oh yeah, the trailer does have surge brakes installed on it.
Thanks guys.
Old Mar 6, 2014 | 03:17 PM
gvsu4msu's Avatar
gvsu4msu
YOu could enter your VIN into this link https://dodgeforum.com/forum/vindecoder.php and it should tell you if you are good to go or not.
I did it for my 03 SXT w/ 4.7L and I got:
Dead Weight Hitch - Max Trailer Wt. 2000 lbs (2000.0 min/2000.0max)
Dead Weight Hitch - Max Tongue Wt. 200 lbs (200.0 min/200.0max)
Wt Distributing Hitch - Max Trailer Wt. 5750, 4450 lbs (4450.0 min/5750.0max)
Wt Distributing Hitch - Max Tongue Wt 575, 445 lbs (445.0 min/575.0max)
One other thing to consider was your hitch part of the Tow Package from the factory or aftermarket installed?
Old Mar 6, 2014 | 04:55 PM
dxloat's Avatar
dxloat
It should not be a problem, you are within the 7300 lb tow capacity for your truck if yours has the tow package, which I believe meant 3.92 gears, trans oil cooler, and factory receiver.
Old Mar 6, 2014 | 05:01 PM
ericcarr2000
I'm not sure of the hitch. All I know is there is one that has the 2 inch receiver on it, and I have the little button on the end of the column shifter that you can turn the overdrive on & off. Does that mean I do have the tow package?
Old Mar 6, 2014 | 05:39 PM
dxloat's Avatar
dxloat
Do you have the trans aux trans cooler? It should be in front of the radiator. I think the trans cooler only came stock with the factory tow package. There is a big difference in tow capacity between the 3.92 and 3.55 axel gearing. Check the build sheet if possible or there is usually a small metal tag the size of a dime held by one of the differential cover bolts with the ratio stamped on it.
Tow Limit (lbs.)
Durango 2WD 4.7L V-8 (f) 4650
Durango 2WD 4.7L V-8 (g) 5950
Durango 2WD 5.9L V-8 (f) 5850
Durango 2WD 5.9L V-8 (g) 7550
Durango 4WD 4.7L V-8 (f) 4400
Durango 4WD 4.7L V-8 (g) 5700
Durango 4WD 5.9L V-8 (f) 5600
Durango 4WD 5.9L V-8 (g) 7300
(f) 3.55 axle ratio
(g) 3.92 axle ratio
Old Mar 6, 2014 | 06:15 PM
ericcarr2000
There is some sort of a cooler mounted in front of the radiator, pretty sure it is a trans cooler though. When i had to replace the front differential, I thought they put in a 3.55 gear ratio...Don't quote me on this though.
Old Mar 6, 2014 | 06:17 PM
ericcarr2000
If I get you guys the VIN would that be more helpful?
Old Mar 6, 2014 | 06:28 PM
ericcarr2000
This is from the drivers side door jamb. On the tag it states, GAWR front 3600 lb. GAWR rear 3850 lb. What does this mean?
Old Mar 6, 2014 | 06:38 PM
ericcarr2000
And the VIN is, 1B4HS28Z01F528189
Old Mar 6, 2014 | 06:41 PM
dxloat's Avatar
dxloat
It is not necessary to post you vin here just use the vin decoder link in the guy aboves post. The cooler your seeing is probably the AC radiator, sorry I forgot to mention that before, it would be in front of that. From what you are saying I am guessing you don't have the optional factory tow package but check the vin to be sure.
