hi from ky Steven meek. need 411
Old Mar 10, 2014 | 07:59 PM
smeek66's Avatar
smeek66
Question hi from ky Steven meek. need 411
00 .4.7 durango Top half of the engine have been rebuilt i had New valve seats and stems valve springs clean shaved and checked I have replace camshaft sensors crankshaft sensors and it keeps coding and wont Start at wits at wits end need help.PCM maybe Bad ? anything I can check
Old Mar 11, 2014 | 08:14 AM
Welcome to DF. For future reference:
https://dodgeforum.com/forum/new-mem...-yourself.html
Moving to the correct section.
Old Mar 12, 2014 | 05:28 PM
hydrashocker's Avatar
hydrashocker
What codes?
Old Mar 12, 2014 | 08:47 PM
smeek66's Avatar
smeek66
Originally Posted by hydrashocker
what codes?
p0340
Old Mar 13, 2014 | 11:09 AM
hydrashocker
P0340 No Cam Signal At PCM
Hopefully you removed the negative battery cable before you installed the cam sensor, if not when you plug it in it can fry it. Also you could have a bad one, so I would say take it back and replace it again this time remove the negative battery cable and secure it.
Also I see that the head was rebuilt. If the shop or you did not reinstall the correct cam lobes and installed 32 tooth instead of 16 tooth, or visa verse, it would not start.
Your PCM should have 3 plugs which would conclude you have a 16 tooth system. If it has 4 plugs then it is a 32 tooth system. The cam lobes and fly wheel need to be the same type system for the PMC to run it....aka....16 tooth cam lobes with 16 tooth fly wheel with 16 tooth PCM.
Old Mar 13, 2014 | 06:40 PM
smeek66's Avatar
smeek66
Default hi Steven meek from ky looking for ideas
I have 00 durango 4.7
will not start i have replace timing chain replace timing change. timing is correct replace camshaft sensors call pack I have fuel pressure coil packs i got have fire will not start just turns over
Old Mar 13, 2014 | 09:21 PM
gvsu4msu's Avatar
gvsu4msu
are you typing this on a phone? It seems like auto-correct is taking over.
Old Mar 13, 2014 | 09:41 PM
smeek66's Avatar
smeek66
Yes sorry for typo my problem is i got a 4.7 that was running. Then died i got fuel ,sparkplugs fire and engine wont Start keeps coding p0340 camshaft Sensor i have replaced it 3 times
Old Mar 13, 2014 | 09:50 PM
smeek66's Avatar
smeek66
Default 00 durango got me lost
What i have is a 4.7 that wont Run it did then just died. What i Do have is fuel pressure spark to the plugs. It keeps coding p0340 and i have replaced the camshaft sensor 3 times and keeps coding it i have replaced the Timing chains the marks are dead on crankshaft sensor replaced 3 times to i am So lost
Old Mar 14, 2014 | 01:26 AM
DyingBreed's Avatar
DyingBreed
How about keeping your posts in one thread instead of multiple threads for the same issues. Keeps the confusion down and you are more likely to get help instead of clogging up the forum with several threads for the same issues.
