99 Durango - Transmissio - in drive @ stoplight -> high rev when push gas
Old Mar 30, 2014 | 05:28 PM
adukart's Avatar
adukart
Originally Posted by shrpshtr325
just purge it out, there is a thread in the FAQ on how to do this, basically you just let the trans pump itself out while you add more to it
+1, very easy to do especially if you have someone there to run the ignition for you. Also Valvoline ATF+4 is a favorite here. The dealership I work at sells the mopar brand (castrol) ATF+4 in bulk for like $6-7/qrt, just gotta get a container. Also when I purged mine it took about 15qrts so 4 gallons will do it with some to spare, maybe use that in the transfer case (the transfer case is around 2qrts iirc).
Old Mar 31, 2014 | 03:29 PM
realestateguy's Avatar
realestateguy
Thanks guys. Both of the post below are VERY helpful. I saw a strong recommendation for a dealership on the second link. Any dealership rec's or independent shops that any of you trust in the Boston area (South Suburban if possible)
Thanks
JE
https://dodgeforum.com/forum/1st-gen...nsmission.html
https://dodgeforum.com/forum/1st-gen...nny-flush.html
