Brake light and abs kick on an off
Old Jul 9, 2015 | 11:43 PM
learningauto's Avatar
learningauto
New Member
Default Brake light and abs kick on an off
So ive got a 98 dodge durango 5.2L and the abs and break lights kick on and off. i have replaced front only pads, routers and calipers. today when i came to a stop it made a weird noise defiantly came from the break system i could feel it in the peddle. i didnt looses break pressure that i could tell and the breaks did work. I would prefer not to have to change both the break booster and the master cylinder just to find out its not that. i hate driving and not knowing if its just going to fail to stop one day. ive had the car on a code reader and no codes came up. where do i start now?
Old Jul 10, 2015 | 01:32 AM
dxloat's Avatar
dxloat
ABS module is cycling, could be a bad module, bad abs wheel hub sensors, or trans speed sensor. If you changed calipers you could have gotten air in the abs unit which needs to be bled with a drb scan tool pretty much only found at a dealership. Constant cycling likely abs module, it was for me anyway. Tried a rebuild service and they couldn't get it right so I bought one off ebay used for around $100. It is my understanding abs modules are programmed for the specific vehicle specs so you may need that drb tool again. I just bought one with exact matching numbers and it worked and that was good enough for me.
Old Jul 10, 2015 | 10:07 AM
Mattbak's Avatar
Mattbak
Check the wheel hub abs connections. Pop both of them off clean them out and reconnect them. Thats what happened with my D and abs problems. One loose plug.
Old Jul 10, 2015 | 05:24 PM
learningauto
New Member
i will defiantly look into all of that. i have a mechanic friend who is going to check my back breaks out for me and i will talk to him about these possibilities. i will let ya all know what i do find out.
Old Nov 26, 2020 | 12:59 PM
JMacLeod's Avatar
JMacLeod
Wow, to be honest I have never seen something like that. I mean,abs module getting burned out, that is not what you get to see everyday.
Old Jan 25, 2021 | 11:34 AM
LeonDuitz2009's Avatar
LeonDuitz2009
Hate to be a hitchhiker on this thread,
I was curious if this issue would always be an abs module or just a wheel sensor?
My abs and brake light come on, but only after driving a couple minutes. it stays on after that until I shut off the vehicle, and then it starts all over again.
Old Jan 25, 2021 | 11:47 AM
Get the codes read, and see what it is whining about.
Old Jan 27, 2021 | 06:22 PM
LeonDuitz2009
Exclamation
Checked the ODB, no codes being thrown when the lights show up or when the vehicle is off. I am thinking its a speed sensor, when the warning lights pop up, my cruise control will not engage.
HOw does one test Abs sensors or speed sensors?
Old Jan 28, 2021 | 09:01 AM
Need a scanner that can read live data. There are three of four wheel speed sensors, and a selection of switches that could be the problem.
