What size motor will fit in a 2002 dodge durango..
Old Jan 19, 2016 | 10:42 AM
Erykah Quintana's Avatar
Erykah Quintana
Default What size motor will fit in a 2002 dodge durango..
So I bought my durango sat motor blew sun.. Will a 2000 dodge durango motor fit in my 2002..
Old Jan 19, 2016 | 10:49 AM
What engine is currently in it and what size engine is in the 2000?
Old Jan 19, 2016 | 01:09 PM
JeeperDon's Avatar
JeeperDon
Note that some state DMVs won't let you swap an older motor into a vehicle.
Old Jan 19, 2016 | 08:50 PM
Erykah Quintana
The 2000 is 4.7 I guess mine is 5.9 360..
Old Jan 19, 2016 | 09:25 PM
Completely different. It will fit but not without a lot of other work.
Old Jan 19, 2016 | 09:27 PM
Erykah Quintana
OK.. So what other motor can I put in there it has to be a 2002 5.9 can I use like a doge ram 5.9..and how do I know If you my motor is blow..
Old Jan 19, 2016 | 09:29 PM
You're the one who said it was blown. What makes you think it's blown? What exactly is blown?
Old Jan 19, 2016 | 09:33 PM
Erykah Quintana
Well from reading about the dodge durango the motors blow easy.. So my oil pressure was at 0 and I was driving it and everything shut off and a little smoke came out.. The oil pressure would go up then drop to 0..we replaced the sensor happened again was told by auto zone it's something electronic for the sensor to keep blowing like that.. Truck had oil no sludge in pan..
Old Jan 19, 2016 | 09:39 PM
Does it run or not. Describe in detail what has happened and what you have done so far yourself. I can't keep guessing. Need more info.
Old Jan 19, 2016 | 09:50 PM
Erykah Quintana
MY battery is dead.. I dont know if it turns on or not I will know this weekend.. Thanks so much for replying to me..
